Re: 1967 427/400 ignition coil
Thanks again for your feedback. I did order a coil from Napa that was recommended in a another post on this forum. That will (should) rule out the possibility that the coil is the culprit. I will however post the other detail as a new topic becasue the question remains as to whether the higher resistance readings on the 264 coil are correct.
