Re: C2 oil pump and gaskets
Rich------
For a 1963 340 HP you should do as Duke mentions. Check your oil pressure gauge range. If it tops out at 60psi, then use the standard volume, standard pressure pump. If it tops out at 80 psi, then use the standard volume, high pressure version.
The problem with aftermarket pumps, though, is that, usually, none of the springs supplied will produce pressure the same as either of the original GM springs.
Rich------
