57 Three Speed Transmission - NCRS Discussion Boards
  • Greg K.
    • September 30, 1985
    • 35
    Were the 1957 3 speed transmissions and/or tail pieces painted? I can't find anywhere this is discussed.
  • Rod K.
    • 445
    Re: 57 Three Speed Transmission
    Quick scan of the judging manual gives no indication of paint except for std trans bell housing, engine color. Believe it was painted as part of the engine assy in Flint. AFAIK, trans case and tail were unpainted
    • Joseph L.
      • July 26, 2012
      • 162
      That is correct. The JM does not have information. However, if it is hot tanked by your machine shop, it will rust. A light coat of Cast Iron Gray engine enamel spray paint will solve the rusting and produce a finish that is hard to identify that there is paint on it. It appears to be bare cast iron.
      Joe
      • Mike M.
        • May 31, 1974
        • 8409
        agree with Rod and Joe, the 3 speed 57 corvette trannys were unpainted, have provision on tail housing to mount the shifter ,and all were close ratio gear sets. mike
        • Greg K.
          • 35
          • Steven B.
            • June 30, 1982
            • 4016
            As has been said before, and after, rebuild no paint on my 57 3 speed.
            • Gary C.
              Administrator
              • October 1, 1982
              • 17970
              Basic rule for painting was "if a prospective buyer could see it, marketing wanted it to be painted".
              Once told to me by John Hinckley.
              Gary
              NCRS Texas Chapter
              https://www.ncrstexas.org/
