Restamped blocks using a CNC - NCRS Discussion Boards
  • Keith B.
    • September 15, 2014
    • 1582
    A issue occurred at a judging meet where a stamp pad on a low optioned 327/300 was deemed to be non typical pad surface and the "stamping" done by a CNC using dot matrix engraving. But upon further cleaning the pad with a cleaner to remove a proactive oil it was deemed a factory stamp but still a non typical finish. While the owner believes doing machine work the block may have been sandblasted to clean things up which would warrant the non typical finish. So no argument there.
    however how often are team leaders finding "restamped" engines pads using the dot matrix engraving.
  • Larry E.
    • 1677
    Re: Restamped blocks using a CNC
    Keith or Anybody>Like to see a picture on the above process. Never heard of this before. Larry
    Larry
    LT1 in a 1LE -- One of 134
    • Keith B.
      • 1582
      Well Larry I believe C4 era GM pads are done that way. But I never seen one out side of a GM done pad.
      • Gary J.
        • April 1, 1980
        • 1241
        Did you take a picture of the pad?
        • Mark F.
          • July 31, 1998
          • 1524
          This is on aluminum, but I'm guessing the concept is the same for cast iron.
          Also interesting that these can be scanned...
          thx,
          Mark
          • Mark L.
            • 560
            The picture is of a 92 LT1. The block is iron and this looks like a stamp. I believe the ZR1 was a dot matrix.
            • Brian M.
              • November 1, 1994
              • 124
              I believe the C4 VIN number is a dot matrix.
              i am in Las Vegas and do not have access to my computer to provide an example.
              Brian McIntyre
              • Mark L.
                • 560
                This is the vin stamp. Very poor picture but I believe it is also a stamp.92vinpad 004_LI.jpg
                • Brian M.
                  • November 1, 1994
                  • 124
                  Mark,
                  You are correct, it is a stamp.
                  This was taken from a block out of the car.
                  Brian McIntyre
                  • Mark L.
                    • 560
                    Thanks Brian. That is the best picture of a C4 block vin I have ever seen! Hope you came home with some of your money!
                    • Patrick B.
                      • August 31, 1985
                      • 1995
                      Is N the plant code for Bowling Green or is this a Norwood Camaro? Except for the final 2, these are strange characters, but they still looked stamped.
