Trim Tag Advice - NCRS Discussion Boards
Trim Tag Advice
  • Mark F.
    • July 31, 1998
    • 1524
    Re: Trim Tag Advice
    Mark------The trim plate holes were supposed to be drilled at St. Louis "using the pillar post as a template".
    Originally posted by Owen Lowe (20119)
    The '72 AIM (UPC 14, sheet F1) says to drill and use the plate as a template; it doesn't indicate any measurements for placement:
    Hence why it could be anywhere in that space...(even bent over)...
    it's "the dog on the day" kinda thingy"
    Still surprising to me that holes, dimples, (or pre-marking of some kind as Jack says) weren't already there w/ the panel; but somebody had their reasons as documented in the AIM.
    FYI - here's what a C2 AIM shows (holes were already there in the bird cage brace at the attachment station):
    thx,
    Mark
    • Owen L.
      • September 30, 1991
      • 868
      Re: Trim Tag Advice
      Originally posted by Deane McGoldrick (46666)
      Looking for a little help on this trim tag. Looks ok to me. But that doesn't mean much.......
      Let me know.
      Thanks.
      Anyone have any other tag from F29? It would take some extra effort to "use the plate as a template" to drill holes in that location. The tag wouldn't even sit flat on the panel to drill them.
      • Jack M.
        • March 1, 1991
        • 1153
        #18
        Re: Trim Tag Advice
        Good idea from Owen to check the AIM's... and since this particular BaT Corvette is a 1969, letz look back.
        This info come from the 1968 AIM... note the dimensions being called out:
        In 1969, the page changed to the following:
        And the REVISIONS (enlarged), indicate some of these changes were very late:
        If someone had an earlier 1969 AIM page, perhaps it might add some clarity.
          • 6942
          #19
          Re: Trim Tag Advice
          Deane, The C3 registry has a data base of trim tags, as it looks they were installed with some variation, some worst than others some with one bent corner and some with both. Of coarse there are alot I would not touch with a 10 foot poll.
          • Jack M.
            • March 1, 1991
            • 1153
            #20
            Re: Trim Tag Advice
            Good thought Ed... and reviewing the Trim Tags just BEFORE and AFTER the VIN in question, they appear SIMILAR to the image Deane posted.
            • Mark F.
              • July 31, 1998
              • 1524
              #21
              Re: Trim Tag Advice
              That's 266,898 hand-placed (random) and hand-drilled holes and rivets from 1968 thru 1972 !
              thx,
              Mark
              • Jon H.
                • January 1, 1999
                • 147
                #22
                Re: Trim Tag Advice
                Let me know.
                Thanks.
                Original factory production trim tag. The tag is from the 69 on BAT for sale currently. Original an L46 car that has been built into an L71 clone.
                  • 43219
                  #23
                  Re: Trim Tag Advice
                  Owen------
                  That's a good point. Note that the rivet holes in the plate are not centered on the "short" dimension of the plate. So, if the plate were used as a template for drilling the holes but the plate was held upside down during the drilling process, then the finished installation would appear just like the one initially pictured here
                  • Kenneth B.
                    • August 31, 1984
                    • 2088
                    #24
                    Re: Trim Tag Advice
                    Owen------
                    JOE My thoughts exactly. They were built on a assembly line with a job #. Not a hand built custom coach auto.
                    • Mike D.
                      • July 31, 1996
                      • 306
                      #25
                      Re: Trim Tag Advice
                      I was wondering if the body build matched the VIN production date.
                      Mike Doty
                      Intermountain Chapter Judging Chairman
                      Region VIII Director
                      • Owen L.
                        • 868
                        #26
                        Re: Trim Tag Advice
                        • Jon H.
                          • January 1, 1999
                          • 147
                          #27
                          Re: Trim Tag Advice
                          Here is another trim tag with an F29 build date.
                          • Mark F.
                            • July 31, 1998
                            • 1524
                            #28
                            Re: Trim Tag Advice
                            Did '68s to '72s not have body sequence numbers (BSNs) like C2s did ?
                            or, if they did were they located somewhere other than the Trim Plate ?
                            thx,
                            Mark
                            • Owen L.
                              • 868
                              #29
                              Re: Trim Tag Advice
                              Not my '72 anyway. It's not on the trim tag or door label. Guess it was decided that it wasn't important to track.
                              • Tim G.
                                • March 1, 1990
                                • 1374
                                #30
                                Re: Trim Tag Advice
                                I think you guys are on to something with two F29 trim tags mounted too high. They more or less validate each other.
