Matching Numbers? - NCRS Discussion Boards
Matching Numbers?
  • Rick B.
    Infrequent User
    • December 10, 2016
    • 17
    Matching Numbers?
    So here is my dilemma. Picked up a 1974 Vet with a 454 engine. After spending some time cleaning up the engine I am perplexed about the engine stamping. I have heard about stamping problems at the factory specifically in the assembly process where the stamps were double stamped and had partials on the block etc. Unfortunatley, I have one of those. I have attached a picture. At the start you can see CW then it appears someone may have taken a die grinder and cleaned up a screw up in the assemble stamp. By doing so they took out the remaining symbols of the Tonawanda stamp. The car has an automatic in it, so I think the top of the third letter is probably a R. The font on the vin numbers appears to be correct for that year. But it is double stamped. The Block casting number is correct and the Vin number does match the vin on the car. Thoughts?
  • Owen L.
    • September 30, 1991
    • 842
    Re: Matching Numbers?
    Can you post a pic of the entire pad looking as vertically as possible?
    What does the engine plant stamp before the CWx code look like?
    What is the engine's casting date (on the top of rear flange, passenger side)?
    • Rick B.
      Infrequent User
      • December 10, 2016
      • 17
      I will take another pic today when I get to the shop. The second picture is of the block casting number on the back.
      • Owen L.
        • 842
        The casting date will be on the passenger side of the flange from the casting number. That will at least help place the block in the proper lead time for the VIN. If you were so inclined, the heads also have casting numbers and dates. If original to the block, they should be about the same date.
        • Dan A.
          • May 31, 1974
          • 1074
          • Rick B.
            Infrequent User
            • December 10, 2016
            • 17
            Here are a couple of photos of the complete pad and then closeup of the two numbers.
            • Edward C.
              • August 13, 2014
              • 144
              It looks like it’s triple stamped. Just like I said on the CF board. The first vin stamp looks ground out and went into the assembly code stamp. The second one was low and off the pad and the third is readable. Hopefully the guys who know pad variations better will post there opinions. Very interesting.
              • Justin S.
                • July 3, 2013
                • 289
                The assembly stamp looks too close to the leading edge of the pad
                • Tim G.
                  • February 28, 1990
                  • 1360
                  Wow, I wouldn't change a thing. I'd show that Corvette and be proud of the stamp until it is proven otherwise. The first one was a grind out, the second one was off the edge and the third one was legible.
                  • Rick B.
                    Infrequent User
                    • December 10, 2016
                    • 17
                    Thanks Tim, I sent you an e-mail in the NCRS system and I was not sure you got it. I had another question on the Blue 63 Fuelie in that e-mail if you can find it.
                    • Tim G.
                      • February 28, 1990
                      • 1360
                      Rick, I just checked my messages and do not have any pending. My box is clear, so it should have made it. I'll send you a message.
