How to free shoulder belt from seat slot? - NCRS Discussion Boards
  • Mark E.
    • April 1, 1993
    • 4552
    How do I get the shoulder belt free from the seat back? I tried wiggling it through the slot without luck. The escutcheon on the back side is unscrewed. I'm doing this because I need to remove the seat from the car.
    Mark Edmondson
    Dallas, Texas
    Texas Chapter
  • Tom L.
    • October 17, 2006
    • 1439
    Re: How to free shoulder belt from seat slot?
    Well this was a challenge for me too. Mostly since I didn't have the tool required. Having little hair I just didn't have a hair dryer, so I borrowed one from the wife with the promise that I'd return it in great shape. Joking aside, pull the belt out, heated the rubber (?) cover over the end of the belt with a hair dryer until it becomes soft and it should pull right off. Do the same when putting it back together. Was pretty simple. Hope this helps!
    • Mark E.
      • April 1, 1993
      • 4552
      Thanks Tom.
      I was hoping there is a trick to free the belt without removing the sleeve, but maybe there isn't. I used a heat gun to install the repro buckle sleeve and it was a real bear to get on. If you look at it, I don't think it's positioned correctly... maybe the new piece is a tad small.
      Mark Edmondson
      Dallas, Texas
      Texas Chapter
      • Ralph S.
        • February 1, 1985
        • 935
        Look below in similar threads
        • Mark E.
          • April 1, 1993
          • 4552
          Thanks Ralph. My bad- I usually search a topic before posting.
          It looks like I'll be wrestling the sleeves off with my heat gun. It's a repro so if it puts up a fight I may cut and replace it.
          Mark Edmondson
          Dallas, Texas
          Texas Chapter
          • Patrick B.
            • August 31, 1985
            • 1996
            Mark- I have had my original 70 sleeves off and on a number of times with a heat gun on the LOW setting. It is not as brutal as it sounds.
            • Mark E.
              • April 1, 1993
              • 4552
              It was brutal when I installed them. Maybe the reproductions are a stiffer material or smaller.
              Mark Edmondson
              Dallas, Texas
              Texas Chapter
              • Mark E.
                • April 1, 1993
                • 4552
                An update to close out the thread:
                I heated the sleeve with a heat gun, and it slipped right off! An order of magnitude easier than it was putting it on. Thank you to the folks who posted.
                Mark Edmondson
                Dallas, Texas
                Texas Chapter
                • Sal C.
                  • December 1, 1984
                  • 430
                  Bring a pan of boiling water out to the garage. Dip the end of the belt in and you'll be able to do whatever you want with the boot.
