61/62 Off Road Mufflers - NCRS Discussion Boards
  • Peter M.
    • February 1, 1984
    • 361
    For 1961/1962 Corvette ... I have a pair of what I I believe to be an original pair of off road mufflers with GM part numbers as well as a pair of reproduction units. The original GM are internal two pipe design (bottom picture) while the repro is a chambered "straight through" design. Does the original correspond to what you know as original units? If so ... do other repro suppliers offer the same as original internal design or just the chambered straight through design? I would imagine that the repro would be louder.
  • Steven B.
    • June 30, 1982
    • 4005
    Re: 61/62 Off Road Mufflers
    Peter, I have to get mine out of storage to look and compare to yours. I got them in the late 60's at my local Chevy dealer and they are still in the box. I do recall a couple of years ago comparing off road units from two retailers and they were the same.
    • Peter M.
      • February 1, 1984
      • 361
      Steven
      Looking forward to your finding when you locate those original Off Road mufflers!
      Peter
      • David B.
        • March 1, 1980
        • 689
        Peter,
        What is the part number for your original GM off road muffler. I believe I have the lay out prints with GM photos of the installation of that option.
        • Peter M.
          • February 1, 1984
          • 361
          Hi David,
          The part numbers are as follows:
          GM 3798789
          GM 3798790
          Thanks for looking into this.
          Peter
          • Peter M.
            • February 1, 1984
            • 361
            Sorry - those GM numbers I just provided were the header pipes - mufflers only have embossed (raised) on muffler body 21132 0 A on both - no GM tag ... likely are service replacement I suspect
            • Dennis C.
              • June 30, 2002
              • 884
              Can you post a photo of the outside of the off road mufflers you thought might be original?
              • David B.
                • March 1, 1980
                • 689
                I kinda thought so since they are listed in Grp. 3.609 not the muffler Grp.3.701. The layout print I have predates your part numbers. I think Engineering for this option was originally intended for '60 LeMans with updates in late '61 tied to Front auxiliary stabilizer unit 3823052. A couple of notations indicate 2.25 dia. seamless tubing utilized and for "Racing use" a 2.25 dia. hole was bored thru the length of the muffler. The muffler listed was made from #3741413. This is listed in 1960 from Grp. 3.701 as a truck muffler with a length of 38 5/8 OL. Sorry I could not help more.
                • Peter M.
                  • February 1, 1984
                  • 361
                  Thanks David - much appreciated - I've attached additional pictures as Dennis Crupi requested.
                  • Peter M.
                    • February 1, 1984
                    • 361
                    As requested - see pictures
                    • Dennis C.
                      • June 30, 2002
                      • 884
                      I was looking for those spot welds around the circumference. Thanks for posting.
                      • Peter M.
                        • February 1, 1984
                        • 361
                        So Dennis - reference those spot welds ... is your conclusion then that these examples are indeed original OEM Off Road mufflers which would have been installed on 1961/1962 Corvettes? Further that the two-tube inner tube design was factory vs the reproduction single tube reproduction?
                        • Peter M.
                          • February 1, 1984
                          • 361
                          Re: 61/62 Off Road Mufflers New News!
                          David - I realized that the mufflers do in fact have GM part numbers stamped on the pipes close to the weld to the muffler itself. One is 3813535 - the other opposite muffler has 38135XX with last two covered by the factory weld!
                          • Dennis C.
                            • June 30, 2002
                            • 884
                            I can not comment on the inner tube design.
                            I have attached two photos of off road mufflers from a 1957 4 star Bowtie car. If it wasn't for the part number (211320A) on your mufflers, I would say they look extremely similar.
                            • Dennis C.
                              • June 30, 2002
                              • 884
                              The number 3813535 do not appear in the February 1961 Chevrolet Parts Manual.
                              However, you might want to take a look at this post on the other forum:
                              https://www.corvetteforum.com/forums...-mufflers.html
