1964 Gauge Cluster capacitors - NCRS Discussion Boards
  • Ron L.
    • July 31, 1998
    • 113
    Someone out there have a picture of the back side of a 64 gauge cluster with capacitors attached. Can't quite figure out the orientation of the mounting brackets and to which screws. The AIM suggests both capacitors are attached to the screws securing the bottom of the gauges, but the edge of the capacitor brackets seem to bind up against the housing. It appears the capacitors should be horizontal when attached. BTW - the brackets are original, but I failed to take a picture some years back when I removed stuff and restored the cluster. Any help appreciated.
  • Don H.
    Moderator
    • June 16, 2009
    • 2280
    Re: 1964 Gauge Cluster capacitors
    Ron-
    the capacitors DO bind up against the housing.
    • James W.
      • December 1, 1990
      • 2671
      This is not a '64 cluster, but a '65. Thought some of these pictures might help for placement of wiring and bulb connections.
