As part of my 1969 L-46 350 /350 AC, PS. PB coupe restoration, I pulled my radiator and core support out because the core support was rotted out in the lower RH corner where the lower hose connects. New core support ordered from Coffman Corvette out of Mansfield, OH through Zip Corvette, along with new seal kit.
My question is the dents I see in the upper and lower radiator hose connections. I am pretty sure the dent in the upper hose connection is from someone cranking down too hard on a tower clamp in the past so I can have that one straightened out.
I am not sure about the larger dent in the lower hose connection. I don't know if that dent is intentional for clearance or did someone crank too hard on a tower clamp on that connection too? I don't want to have that dent pounded out and straightened if it is supposed to be there for clearance? So, I am asking the experts.
Also - when I dropped off my radiator, the owner showed me a steel embossed radiator tag (photo example attached). Does anyone know if there is a company that produces the MK9 radiator tag with GM Part No. 3018803 stamped along the bottom? The tag is shown on P. 194 of my 6th Ed. TIM&JG. As long as I am restoring the radiator, it would be nice to source this radiator tag and clip it back on the radiator.
Kevin
(KS69Coupe)
Kevin
(KS69Coupe)
