DOT 5 compatibility testing of actual Lone Star brake seals - NCRS Discussion Boards
  • Patrick B.
    • August 31, 1985
    • 2011
    This is a continuation of several threads discussing the reasons why Lone Star and other Corvette brake suppliers warn against the the use of DOT 5 silicone brake fluid in their calipers and master cylinders. This policy created a particular problem for those of us who wanted to use DOT 5 fluid for its advantages of preventing rust and avoiding risk to our very expensive paint jobs with the o-ring type brake pistons that are only available from the specialty Corvette brake suppliers who warn against DOT 5 use.
    The reason given by Lone Star for this policy was that DOT 5 fluid had changed over the years and was now incompatible with brake seals. Tests conducted by TDB members recently demonstrate that this theory is false. DOT 5 fluid has not changed. Mark Lincoln had a number of new and old DOT 5 fluids tested under FTIR Spectroscopy. I have attached that study as a pdf file (I hope it actually attaches). It shows the Spectroscopy signatures of the various fluids to be almost identical. I have also reported compatibility tests of EPDM rubber o-rings and two kinds of silicone brake fluid, a preproduction Dow Corning fluid made in 1977 and a current DOT 5 fluid sold under the Carquest brand. The EPDM o-rings passed the material compatibility test with both the new and very old silicone brake fluids. This test is on the TBB under the thread name: Final Test Results of Brake Caliper O-rings with Silicone Brake Fluid.
    So, if the DOT 5 brake fluid did not really change, why are the brake suppliers worried their products will fail if we use silicone brake fluid? The only reason left is that the rubber in the seals is different. I have Lone Star calipers with o-ring pistons on my 67 Corvette and my friend has CSSB o-ring pistons (sold by Zip) on his 65 Corvette. We used my supply of the old Dow Corning fluid on both cars about 5 years ago, and we have not experienced problems. These cars are not driven very much and certainly not in a way that heats the brakes a lot. I had assumed that the warnings were out of an abundance of caution because the suppliers did not know what kind of rubber the o-rings were, but that they were probably some type of EPDM because they seemed OK in cars I knew had DOT 5 fluid in them. Peroxide cured EPDM is the best material for brake seals, but the much cheaper sulfur cured EPDM also performed ok in the compatibility I ran. So maybe the o-rings were the cheaper EPDM?
    The material compatibility test involves submerging the rubber samples in the DOT 5 brake fluid at 248 degrees F for 72 hours. It is an accelerated test and the failure mode of the rubber is swelling and softening. Jim Schwering, who is active on the TDB, sent me front and rear o-rings of unknown rubber from Lone Star rebuild kits so they could be tested in the same manor as the known EPDM o-rings I tested previously. Much to my surprise, the Lone Star o-rings failed miserably. Both had a section width of 0.210". The section width is easy to measure with accuracy before and after the test. These o-rings were highly affected by the exposure to hot DOT 5 fluid. They failed the test by expanding the section width from 0.210" to 0.240", and becoming much softer. The first picture shows the front and rear o-rings that have gotten "fat" along with a normal size front o-ring for comparison.
    Gary Beaupre, another active member of the TDB, gave me parts from a 66 Corvette single master cylinder rebuilt by Lone Star. One part was a lip seal cup and the other was lip seal ring that I was able to remove from the piston without damage. I printed (after several tips from Gary) a series of circles increasing in .005" diameter increments that Gary had sent me for estimating the growth in diameter of the parts from the exposure test. The lips were slightly different between the two pieces, with the cup overlaying the 1.047 circle pretest and the ring overlaying the 1.052 circle. The picture to the right shows the parts after the exposure test. The cup lies within the 1.052 circle and the ring seal lies easily within the 1.057 circle. It is very hard to measure precisely a soft surface like a lip seal, but the circles indicated to me that the seals had expanded by less than 0.005" and perhaps not at all. Also I do not think any change in hardness occurred during the test. My conclusion is that these pieces pass the test, and that they are probably EPDM rubber either peroxide cured or sulfur cured.
    This result seems to say that the master cylinder parts used by Lone Star came from a normal brake parts manufacturer who used some kind of EPDM rubber which should be universal in that industry. But the o-rings must come from some manufacturer who is not in the regular brake parts industry and does not know the business. I do not know if the o-ring piston kits from Lone Star and CSSB are supplied by the same manufacturer but they use the same size o-rings and the pistons appear to be identical in their machining. If they are from the same manufacturer, that company has not even used a chemical compatibility chart such as the one on the website of theoringstore.com. The o-rings I have seen are not even recommended for DOT 3 conventional fluid. The extra cost "high temperature" CSSB kit I bought from Zip used silicone o-rings. The chemical compatibility chart predicts that silicone o-rings would swell at least 20% in DOT 3 conventional fluid. The only o-rings recommended by the compatibility chart for even DOT 3 conventional brake fluid are EPDM and Simiz FFKM. The later is so exotic that a single o-ring costs an unbelievable $138.08, compared to $1.67 for the same size peroxide cured EDPM o-ring. We know the Lone Star o-rings are not EPDM because they failed the compatibility test for DOT 5 silicone brake fluid (which both flavors of EPDM o-rings passed), so they are made of something not even recommended for DOT 3 by the compatibility chart. It does not appear that even the most basic diligence was used in the choice of o-rings for the o-ring piston kits. The material is not what would be recommended for DOT 3 or DOT 5 fluid.
    I am now concerned about my car and really all others using the Lone Star and CSSB o-rings. The o-rings in my car have not yet failed. It has been suggested that maybe the o-rings used by Lone Star 5 years ago were really EPDM but they were different in the kits Jim Schwering bought recently. I don't think that is likely. A manufacturer who understood that EPDM was really the only o-ring material recommended for any brake fluid would not have changed to something else. Therefore, we know that we are using o-rings that will fail an accelerated test in 3 days. The only question is how long they take to fail under the benign conditions of our lightly driven mostly parked restored cars, and this includes cars using DOT 3. When I get home from Florida, I am going to take at least one caliper apart to check its state of failure and replace the o-rings with peroxide cured EPDM that I know are compatible with DOT 5 (and DOT 3). If the o-rings I remove still look good, I will give them the accelerated test with DOT 5 to see if they are EPDM (unlikely IMHO).
  • Mark L.
    • 561
    Re: DOT 5 compatibility testing of actual Lone Star brake seals
    The reason given by Lone Star for this policy was that DOT 5 fluid had changed over the years and was now incompatible with brake seals. Tests conducted by TRB members recently demonstrate that this theory is false. DOT 5 fluid has not changed. Mark Lincoln ha wd a number of new and old DOT 5 fluids tested under FTIR Spectroscopy. I have attached that study as a pdf file (I hope it actually attaches). It shows the Spectroscopy signatures of the various fluids to be almost identical. I have also reported compatibility tests of EPDM rubber o-rings and two kinds of silicone brake fluid, a preproduction Dow Corning fluid made in 1977 and a current DOT 5 fluid sold under the Carquest brand. The EPDM o-rings passed the material compatibility test with both the new and very old silicone brake fluids. This test is on the TRD under the thread name: Final Test Results of Brake Caliper O-rings with Silicone Brake Fluid.
    This result seems to say that the master cylinder parts used by Lone Star came from a normal brake parts manufacturer who used some kind of EPDM rubber which should be universal in that industry. But the o-rings must come from some manufacturer who is not in the regular brake parts industry and does not know the business. I will add more comments soon, may as an edit.
    Very interesting Pat! Seems like the best thing to do is to test the "suspect" rubber material to understand what the difference is.
    • John F.
      • March 23, 2008
      • 2418
      Or encourage Lone Star to use the proper O-rings. Especially since a number of people on the forums have recommended them to resleeve both master cylinders and wheel cylinders.
        • 43273
        Patrick------
        Excellent work and information.
        By the way, even DOT 3 and 4 brake fluid requires the use of EPDM rubber seals. So, if the brake parts suppliers are using some other type seals, they're not even approved for the fluids they recommend.
          • 15631
          Excellent suggestion John, but we have to recognize the realities of the marketplace. Those of us who are primarily interested in preservation of our Corvettes are in the minority. Most of the customers of any of these suppliers to the Corvette community are overwhelmingly drivers and don't care what kind of brake fluid they use.
          The best we can hope for is a "preservation: package" at an upcharge. That would include the proper O-rings and master seals. I could certainly live with that.
          I wouldn't mind more transparency on the part of the vendors with regard to their material, but in today's market I realize that is asking too much.
          • Patrick B.
            • August 31, 1985
            • 2011
            Joe- I was writing more material when you responded. In the new material I wrote about the same point - Lone Star and CSSB are using o-rings that are not even recommended for DOT 3 fluid. Clearly, there is a large dose of incompetence involved with the o-ring selection in this safety critical equipment.
            • Leif A.
              • August 31, 1997
              • 3651
              Patrick,
              Terrific article and important information. Have you attempted to pass this credible/safety related information onto Lone Star Caliper or CSSB? How are they allowed to sell such an important (life saving) component with O-rings and seals that will fail in short order? Is there no government agency that has oversight on this industry? It can't be a cost issue because, as you noted, the correct seals/O-rings are not very expensive at all.
              Maybe a formal letter signed by those here on the forum asking "why" might get some response. I can't believe either company would want this kind of information to hit the WWW.
              Leif
                • 43273
                Patrick------
                It might not just be their o-ring calipers. As I understand it, they don't approve of DOT 5 in their lip seal calipers, either. So, I suspect it could very well be that the lip seals they use are not fitted with cured EPDM seals.
                • Patrick B.
                  • August 31, 1985
                  • 2011
                  • Patrick B.
                    • August 31, 1985
                    • 2011
                    Patrick------
                    I am less suspicious about lip seals because like the MC parts that tested as likely EPDM they come from a company that actually makes replacement brake parts. Presumably manufacturing companies in the brake business have some understanding of material compatibility. But there is always Chinesium. I would test some Lone Star caliper lip seals if someone has some to donate. Clearly, the disapproval of DOT 5 was misapplied by the Corvette brake suppliers as a cover the a$$ move.
                      • 11692
                      Patrick,
                      Did you test any brake caliper lip seals, or just the MC ones?
                      I have not personally seen Raybestos caliper lip seals leak. Ironically, it was the o-rings sealing the two halves of the caliper that caused the leaking.
                      PH
                      • Leif A.
                        • August 31, 1997
                        • 3651
                        Leif— Some people think that folks at Lone Star are following our threads, so maybe they will take more interest in the kind of rubber these o-rings are made of. I used to work for NHTSA so I understand the limitations of government involvement in this sort of thing. NHTSA is good at regulating vehicle manufacturers, but is not very effective regarding the aftermarket. The safety standards are mostly about the attributes of new vehicles being offered for sale by the manufacturer to the public. There is no standard about rubber in brake systems because no manufacturer would ever use rubber components not compatible with the brake fluid it uses. There is a brake fluid standard because adding or replacing brake fluid is part of ordinary maintenance. But it has been allowed to become obsolete, probably because of political moves like requiring agencies to withdraw two existing regulations for any new one. In the big picture this is a trivial problem that cannot be proven to lead to any crashes or injuries. We are a very very tiny part of the national vehicle fleet, and this is a problem we can solve ourselves. We are actually talking about a vehicle modification, the change from the manufacturers design of lip seals or a design more favorable to cars not driven much, which places this issue even further from government interest. They best thing we can do if we want o-ring pistons is to simply buy peroxide cured EPDM o-rings and throw away the o-rings in the kits. If one of the sellers can assure us that they are supplying those o-rings it will save us the trouble and create a competitive edge for their product.
                        We can only hope. Thank you for your response and efforts on this.
                        Leif
                        • Patrick B.
                          • August 31, 1985
                          • 2011
                          Just the MC seals that were removed from a Lone Star MC. I would be very surprised if Raybestos used seal material other than EPDM which is ordinary for use with DOT 3.
                          • Tom R.
                            • June 30, 1993
                            • 4102
                            Patrick Boyd
                            Your work is most worthy of publication in the Corvette Restorer, which makes its reach greater and public. Then there is the even greater audience that with their backing as companion users of the same technology and vendors could add weight to the argument in support of traditional O-rings and silicone fluid. I'm referring here to the Pontiac, Camaro, and Chevelle users among others. I'm sure they share the same issues.
                            Thinking about this, and I'm sure our moderators can tell us, how many members are regular tech forum users? I'm sure the number subscribed is much greater but I'm looking for perhaps those that tap in at least once a month various the "beyond control posters?"
                            Tom Russo
                            78 SA NCRS 5 Star Bowtie
                            78 Pace Car L82 M21
                            00 MY/TR/Conv
                            • Gary B.
                              • February 1, 1997
                              • 7065
