INDAK C2 Heater Cable & Switch 3849471 becomes 3864600 for (or during) 1964 - NCRS Discussion Boards
  • Tom D.
    • September 30, 1981
    • 2139
    The 1965 HVAC non-Air Cond. cable and switch assembly was sold for service as GM 3864600, group 8.852. The Assembly Instruction Manual (AIM) for 1965 Corvettes also indicates GM 3864600, but there was a prior (1963) version of this part (GM 3849471). When did the assembly manuals reflect this change? (See 2. below.)
    Can't find my 1964 A.I.M., but something tells me it took awhile for the version GM 3864600 to replace the 1963 version. I know from other discussions that the change was to cause "shut off" if the coupe rear fan, when the front (heater fan) was turned on.
    1. Am I right about that reason for the change? Apparently the new version worked ok for convertibles and 1963s...
    2. Does the commonly used version of the 1964 AIM show this change, and a date?
    BTW, A prior discussion started my Mike Garver includes a nice photo from Gary Beaupre. The discussion was about the light under the clock. Gary photographed the back side of an original 1966, showing the installed GM 3864600 cable with harness wires attached.
    To see his photo, click on the https link below, and scroll down a bit.
    Gary Beaupre (28818) NCRS TECH DISCUSSION https://www.forums.ncrs.org/showthre...HEATER+CONTROL
    https://MichiganNCRS.org
    Michigan Chapter
    Tom Dingman
  • Gary J.
    • April 1, 1980
    • 1245
    • Bob J.
      • December 1, 1977
      • 718
      Re: INDAK C2 Heater Cable & Switch 3849471 becomes 3864600 for (or during) 1964
      b
      GM 3849471).
      Tom, I believe the 63 switch and cable was part # 3831677.
      • Alan D.
        • January 1, 2005
        • 2049
        64 AIM calls for 3849471, no changes made
        65 AIM calls for 3864600, no changes made
        It would seem that the 64 cable was change for 65 production.
