Painting original 64 radiator - NCRS Discussion Boards
  • Jim W.
    • April 1, 2006
    • 228
    Finally back on this 64 restore. I have my 63J Harrison radiator out and cleaned pressure tested at local shop (all good) so repainting. They did the fins with special radiator paint but I plan to paint top and bottom with Quanta semi gloss. My question is, should I use a primer or just go straight to the existing surface? Don't think i want to do any sanding, or should I?
    • 11692
    Re: Painting original 64 radiator
    I usually just paint the fresh radiator with Eastwood Radiator paint.
    Priming just adds layers that you don’t need.
