Supplier for correct 56-62 Window runs with white threads - NCRS Discussion Boards
  • Ian G.
    • September 3, 2007
    • 1124
    Hi folks,
    Does anyone know who the supplier is for the correct window runs with felt & white threads for 1956-62 cars?
    I bought a set from Keen Parts, but the part is actually the replacement style without white threads, and may well operate better but incorrect. I informed them they should update their website and will be returning them.
    Most vendors seem to only offer the replacement style except one... I see RPI Designs sells them for a good chunk of change and wondering if anyone knows if they are the manufacturer or they may be available elsewhere?
    Pics of the original-style and replacement window runs
  • Dan B.
    • July 13, 2011
    • 545
    Re: Supplier for correct 56-62 Window runs with white threads
    Unfortunately, it appears the runs with the white stitching have been discontinued. The ones Corvette Central used to sell were excellent, I think they were the supplier. RPI shows them as discontinued as well. Perhaps you might be able to find some new old stock.
    • Ian G.
      • September 3, 2007
      • 1124
      Thanks Dan. Hmm wonder if I can take some black felt and stitch them myself then glue them into a repro stainless window run... does anyone have an original and can check the stitch length?
      • Dan B.
        • July 13, 2011
        • 545
        Ian, I have the white stitched older CC reproductions and they measure 1/8 inch for the stitch with a 1/16 spacing between stiches
        • Gary C.
          Administrator
          • October 1, 1982
          • 17768
          Ian,
          Dr. Rebuild lists them http://www.docrebuild.com/dr-r-web/DR5362C.PDF
          Good luck,
          Gary
          NCRS Texas Chapter
          https://www.ncrstexas.org/
          • Ian G.
            • September 3, 2007
            • 1124
            Thanks Dan.
            Hey Gary, I got my hopes up, but by my reading they are the same as others. He says "Are White stitches really worth an extra fourty (sic) bucks?"
            • Carl R.
              • October 31, 2018
              • 64
              Hello Ian, I have a (62) and needed the same thing done for mine. take your originals and send them off to Restoration Specialties, 1 814-467-9842. They will rebuild your old ones or make new ones for you with the white thread in them. This is what I did and they worked out just great. One of the problems with the other after market ones out there is that the width of the channel is only 3/8 of an inch, and it needs to be 5/8 of an inch wide to go around the window glass chrome molding. The window glass in my car slides up and down very easy with the ones that RS did for me.
              • Ian G.
                • September 3, 2007
                • 1124
                Thanks carl, these guys seem like the ticket! Their catalog is amazing
