1965 rear spring outer mount questions - NCRS Discussion Boards
+ More Options
Posts
  • Joseph E.
    • March 1, 2006
    • 179
    Hello,
    Is the large flat washer installed with the rounded edge facing the rubber cushion or does the rounded edge face away from it? Does anyone have experience with using polyurethane spring cushions in place of the stock rubber ones? I'm wondering if they will last longer and maintain proper ride height better without causing issues or making noise. Thank you.
    Joe
  • Don H.
    Moderator
    • June 16, 2009
    • 2282
    Re: 1965 rear spring outer mount questions
    See this recent thread for all the info you could need.. (the washer curve faces the rubber)
    https://www.forums.ncrs.org/showthre...pring+cushions
    • James W.
      • December 1, 1990
      • 2675
      Pictures of my '65.
      Originally posted by Joseph Evans (45420)
      Hello,
      Joe
      • Leif A.
        • August 31, 1997
        • 3654
        And, use rubber (NOS if you can find them)...poly will disintegrate pretty quickly.
        Leif
