I am in the market for a suitable replacement for a power antenna for my 1965 coupe. Eckler's Corvette has a reproduction for sale and I'm wondering if anyone has used one of those and if so, how does it compare to the original?
					1965 power antenna
Re: 1965 power antenna
Roger, This one?
EK-25-125144-1
If so, it only has the groove on the Main mast section. Originals have grooves on all sections, and the other sections have a extended length so you can see the grooves.
Rich
- Top
Don,
“Implied” date has always been a judging bugaboo for me. Newness alone is not sufficient in my opinion. But I don’t have a good sense when an implied date deduction is appropriate. I would love some guidance and examples.
Gary- Top
I have a 66 antenna with dates on 2 spots of the motor assembly. Since the assembly is dated, I wouldn't take date as it is behind the beeswax. Doubt goes to the owner. I would deduct 20% for configuration for the non typical production antenna.Mike Doty
Intermountain Chapter Judging Chairman
Region VIII Director- Top
Mike,
But if there is no plastic (“beeswax”) coating, then I can imagine two situations where a date deduction could be taken:
- an original antenna (say with the plastic coating removed) and a visible date after the car build, e.g. a ‘66 dated antenna motor on a ‘65 car, then obviously that would qualify for a date deduction;
 - an undated, modern reproduction power antenna or a later GM service replacement (which had no plastic coating) and which are both configured differently from an original, and can therefore be fairly assumed to have been made after the car was built, can have an implied date deduction.
Gary- Top
Roger,
When I replaced my antenna, it was a fixed mount by p o. Replaced with an aftermarket power antenna I purchased from Zip and haven’t had a problem with it since. About 3+ years ago. During judging no points were deducted for it. Just sayin
  Here’s the link.
- Top
Paul,
Thank you for the information and the link. Could I ask you to measure the distance from the base at the fender when the antenna is down and distance when it is extended. Does it have the proper number of extensions.???
Appreciate the help.- Top
