Question On The Infamous "Paint Dimple" On The C2 Firewall Side Facade - NCRS Discussion Boards
  • Larry E.
    • 1697
    Most of us know about the above. Picture Below. I have this on my 66 Coupe (Made Sept. of 65) car.
    Has anybody ever researched (Current Thinking)this to see what are the dates of seeing this from Start To Finish?
    Perhaps my marking is not what is seems to be?? Thanks>Larry
    Larry
    LT1 in a 1LE -- One of 134
  • Mark F.
    • July 31, 1998
    • 1597
    Re: Question On The Infamous "Paint Dimple" On The C2 Firewall Side Facade
    Originally posted by Larry Evoskis (16324)
    Most of us know about the above. Picture Below. I have this on my 66 Coupe (Made Sept. of 65) car. Has anybody ever researched (Current Thinking)this to see what are the dates of seeing this from Start To Finish?
    Larry,
    If you're only talking about C2s (dunno if '68s and beyond had dimples or not?), my car was built and shipped on June 28, 1967 (K28) and it has the dimple.
    My Vin derivative is 21971, so there were 969 cars after mine.
    Last time I heard, Rick Hendrick owns 22940 - dunno if his is dimpled or not.
    thx,
    Mark
    • Don H.
      Moderator
      • June 16, 2009
      • 2282
      I call it a pimple (raised), rather than a dimple (inset). Refer back to this thread for in depth discussion a few years ago.. The question of when they started and when they ended remains unanswered.
      https://www.forums.ncrs.org/showthre...quot&highlight
      • Tim G.
        • March 1, 1990
        • 1417
        I used to know the approximate dates of possible "pimple delete cars" but I've forgotten. I'm sure those with sharper memories than me can fill in the blanks. I'd like to know so I can forget that data again.
        • Larry E.
          • 1697
          Also one wonders if the "pimple" was consistent for Coupes Vs. Convertibles. Like I
          said before my very very early 66 Coupe has it but my very very late 66 Convertible
          does not. ??? Thanks>Larry
          Larry
          • Patrick B.
            • August 31, 1985
            • 2012
            My March 67 St. Louis convertible has it. Since the front surround panel is the same for convertibles and coupes, both should have it. However, if different molds were used for St Louis and AO Smith bodies, that may cause differences. Also since most have these cars have been repainted, some painters probably thought the dimples were flaws that should be sanded off with little effort.
            • Keith B.
              • September 15, 2014
              • 1604
              I thought I read by John Hinckley that there was only one supplier for panels for both plants.
              • Mark F.
                • July 31, 1998
                • 1597
                Hi Patrick,
                This shot is from Michael Garver's post #13 in the following link:
                In the caption at the top of the image, John states there was only one mold...
                To my eye, the pimple would have been created somewhere near the blue circled area...the part is formed upside down, so the side facing us is the passenger side and they're pouring the resin on the headlight bucket end.
                So apparently, the male part of the pimple was in the upper half of the die (above their heads) and the corresponding female indentation was apparently in the die laying on the press bed.
                thx,
                Mark
                • Mark F.
                  • July 31, 1998
                  • 1597
                  Keith, yes - see post #8
                  thx,
                  Mark
                  • Kenneth B.
                    • August 31, 1984
                    • 2091
                    Originally posted by Mark Francis (30800)
                    Hi Patrick,
                    "Below is some information from John Hinckley - rescued from the other forum. The process would suggest that the depression that caused “Pappy” was part of this fixture and therefore the protrusion was formed in the mold on every panel, part of every car - no exceptions."
                    [ATTACH=CONFIG]120581[/ATTACH]
                    There is No male dimple. There would be a round indentation in the half of the mold that made the top of the surround that would make the raised bump on the fiberglass. God knows why its there.
                    • Owen L.
                      • September 30, 1991
                      • 891
                      My May '67 St. Louis coupe has it.
                      • Mark F.
                        • July 31, 1998
                        • 1597
                        Hi Kenneth,
                        If the pimple was made on purpose (and as you say, who knows why ?), the image below represents how the two halves would be made by the die maker. Similar concept to a stamping plant die set - even though this is more of "press-forming" process. I think I remember you saying you had worked in a foundry(?), so this is nothing new for you...
                        Normally, if there's no male dimple (or defect in the die ?), there's nothing up there to squeeze the fiberglass into the female void.
                        But I suppose if the female dimple (defect ?) is there and there's no corresponding male dimple, the fiberglass might have SAGGED into the void under the pressure and heat used to complete the part.
                        Had this been 40+ years ago, I could have asked Earl (the guy in the office next to me) who was PPG's tech services rep for the Ashtabula MFG plant. And the burning questions and mysteries go on and on and on...
                        thx,
                        Mark
                        • Owen L.
                          • 891
                          If it's a male projection, the underside should have a matching "hole"... I've never looked underneath, so don't know if it's there or not.
                          I think it's a flaw in the mold and was the result of the resin pooling in a divot. That Chevrolet didn't catch and fix it early on is par for the course considering they let the waaaaay more obvious valve cover flaw go on for years.
                          • Patrick B.
                            • August 31, 1985
                            • 2012
                            • Kenneth B.
                              • August 31, 1984
                              • 2091
                              MARIK
                              I owned a Pattern shop that made the tooling for foundries & permeant mold shops. For the sand foundries the tooling Is the male version to make the negative sand mold to pour the metal into. Permeant molds are the female tooling to pour the metal or liquid plastic in. There is pressure.to inject Aluminum or plastic so you dont need any pressure from the upper half to squeeze into recesses.
