Fuel sending unit - NCRS Discussion Boards
Fuel sending unit
+ More Options
Posts
  • Donald H.
    • November 2, 2009
    • 2586
    Fuel sending unit
    I had a sending unit restored by Frank Wolf in the past and understand that company no longer does this. I believe there are others who do but are pretty expensive.
    I have an original that I decided to rebuild/restore myself. I have mostly finished but I need to do some sealing around the inside of the base where the terminals go through. I have attached a picture of on that was restored by Frank Wolf and you can see the adhesive/sealer, which is white, covering the inside of the base around the terminals.
    Anyone have a suggestion for a gasoline resistant epoxy or maybe an idea of what the Frank Wolf guy used?
    I have emailed the company to see if they can tell me what he used, but no response so far.
    thanks,
    Don
    Don Harris
    Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
  • Ed S.
    • August 6, 2014
    • 1377
    Re: Fuel sending unit
    Don - sent you a PM -- Ed
    Ed
    • Mark M.
      • October 21, 2008
      • 340
      Don I've tested a number of sealers made for gas and suggested sealers from others and they all failed in a test with gas in a quart can. Surprisingly Brush-on electrical tape from BLUE MAGIC held up well. I was testing it for electrical parts in sending units and it's the only one that lasted. It comes in black ,white and some colors.
      • Gary B.
        • February 1, 1997
        • 7054
        Don,
        Even though John R. Wolfe no longer restores fuel senders, they are still in business and I have to think they know what they used to seal the terminals. Why not call them and ask? Otherwise you might just be going down a long trial and error path that Wolfe has already gone down and found a solution.
        Gary
        • Donald H.
          • November 2, 2009
          • 2586
          Don Harris
