1957 C1 Air Cleaner - NCRS Discussion Boards
1957 C1 Air Cleaner
  • Ronald B.
    Infrequent User
    • August 10, 2017
    • 17
    1957 C1 Air Cleaner
    We own 1957 C1 #E57S105417. It is the 270 hp version with two Carter 4 barrel carbs. The carb id numbers are correct. I have attached 2 photos of the air cleaner base, outside slotted body, air cleaner top, cleanable fiber filter element, and wingnut. The diameter of the components is correct. Both the front and rear carbs have identacal components. I am aware that the wingnuts are not correct. I have researched in the NCRS information manual and judging guide, and other resources, but have been unable to determine if these are the correct parts for my car. All of the aftermarket reproductions are very different from my parts. Can anyone please help me determine if I have the correct air cleaner components for my car? Thanks!
  • Gary C.
    Administrator
    • October 1, 1982
    • 17947
    Re: 1957 C1 Air Cleaner
    Ronald,
    There are good photos and measurements for the 2x4 air cleaners in the '56-7 Judging Manual.
    The outside of the top has 8 columns of 4 louvered vent. The bottom has mesh wire in the section that's over the carb opening.
    Gary
    NCRS Texas Chapter
    https://www.ncrstexas.org/
    • Ronald B.
      Infrequent User
      • August 10, 2017
      • 17
      Hello Gary,
      Thank you for your prompt reply! My Judging Manual is the Fourth Edition, which does not have the photos and measurements. I will need to get the 6th edition ordered. I appreciate your help!
