Broadcast Codes. Are they important in Judging"? - NCRS Discussion Boards
  • George H.
    • March 9, 2017
    • 180
  • Tom R.
    • June 30, 1993
    • 4102
    Re: Broadcast Codes. Are they important in Judging"?
    George, an interesting question but in general and for selected mechanical items, the answer is yes. Broadcast codes confirm that a particular device that was configured for a particular power team, along with its date codes verify the device was engineered for that particular vehicle. There are line items in the judging score sheets that target broadcast codes, though the language may differ...engine is the engine suffix code: Engine suffix code - 25 points. The most prominent items would be your engine suffix code and the carb code. The carb code tells us the power team and emission control system the carb was engineered to accommodate. Atypical codes warrant a deduction, say 20%.Carb date in 73-82 is 5 points...outside the range, full deduct, according to the out-of-date 11/2002 judging sheets. Alternator and distributor also carry codes that are looked and expected to reconcile with guidance in the TIMJG.
    Hope this helps.
    Tom Russo
    78 SA NCRS 5 Star Bowtie
    78 Pace Car L82 M21
    00 MY/TR/Conv
    • Tom R.
      • June 30, 1993
      • 4102
      Here are the engine broadcast codes for an LS4 four-speed taken from the TIMJG
      CWM - LS4 4-speed
      CWR - LS$ THM 400
      CWT - LS4 4-speed CA emissions
      CWS - LS4 THM 400 CA emissions
      Tom Russo
      78 Pace Car L82 M21
      00 MY/TR/Conv
      • George H.
        • March 9, 2017
        • 180
        Thanks Tom, good update. As a follow on question. Are broadcast codes put on the parts at the St. Louis factory? I would think paper labels (i,e, master -cylinder) and ink stamping (radiators, hoses, alternators) are, but, what about parts having a BC stamping like the EGA valve and QJet carb, etc.?
        • Tom R.
          • June 30, 1993
          • 4102
          Of course the engine stamp pad VIN derivative was stamped at St Louis. Otherwise, the manufacturer stamped and applied the code, including date code at their assembly facility. For example, take a look at the QuadraJet whether at Carter or Rochester and we see some variation in the code format.
          The VIN derivative is the only code stamped at St Louis, where it was stamped on the engine pad, transmission and frame.
          Tom Russo
          78 Pace Car L82 M21
          00 MY/TR/Conv
          • George H.
            • March 9, 2017
            • 180
            Excellant informatom. I just lerned a lot.
            • James G.
              • August 22, 2018
              • 808
              For 1973 L82 4 spd Corvette and 1973 Camaro Z28 4 spd, the carb and the EGR are the same part number and same broadcast code.
              James A Groome
              1971 LT1 11130 - https://photos.app.goo.gl/zSoFz24JMPXw5Ffi9 - the black LT1
              1971 LT1 21783 - 3 STAR Preservation.- https://photos.app.goo.gl/wMRDJgmyDyAwc9Nh8 - Brandshatch Green LT1
              My first gen Camaro research http://www.camaros.org/forum/index.p...owposts;u=4337
              Posts on Yenko boards... https://www.yenko.net/forum/search.php?searchid=826453
              • George H.
                • March 9, 2017
                • 180
                James, good follow up. That is the only point I was trying to make with my thread. Same part number, same broadcast code, the part "may" fall within the date code 6 month windown, but, it was not on the same vehicle when leaving the factory! i.e., Corvette, El Camino, Cheville, and maybe even Camaros if they had a 454.
