1963 Fuse Panel Differences - with or without ACC. LPS. - NCRS Discussion Boards
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11329
    If you have a '63 please report back your approximate build date and if your original P.E.D. panel has the ACC LPS terminals or not.
    Original: No ACC LPS terminals. No silkscreen. Note single gray wire fuse clip at center.
    Part # 8670-C upper right side. (observed by eye, hard to see)
    Later Years: Has ACC LPS terminals, 1967 shown
    Repro later year (1967)
    Rich
  • Harry S.
    • July 31, 2002
    • 5330
    Re: 1963 Fuse Panel Differences - with or without ACC. LPS.
    Rich, wasn't the ACC LPS added to accommodate the bulb with the green shade behind the heater knobs, starting in late 64 or 65. I've not seen the ACC LPS on an original 63. But on a 63, never say never.
    • Richard M.
      Super Moderator
      • August 31, 1988
      • 11329
      Harry,
      They added the terminals for something to plug into it, not for any in-car added lamps. The modified the main harness for those. (Edit: No this was a error on my part) Harry was right.
      Rich
      P.S I edited my original post, a lot, as I had a wrong panel shown.
      • Richard M.
        Super Moderator
        • August 31, 1988
        • 11329
        Harry, You were absolutely correct. Those extra lamps were for the C60 A/C backplates plugged in there at the ACC LPS terminal. Thanks for your info and image from the 1965 AIM(see below). I checked the 1964 AIM and it shows the same configuration also. 1963 AIM does not and as you said they added those lamps in 1964 to 1967.
        Rich
