C1 Rear Window Run - NCRS Discussion Boards
C1 Rear Window Run
  • Sheldon S.
    • March 1, 1999
    • 481
    C1 Rear Window Run
    I had to rebuild the fibreglass where the Rear Window run mounts. Now need to drill new holes and need either some measurements or good picture might work also. Also need the size of the hole as I am assuming it needs to be bigger than the screw size so room for adjustment.
    Sheldon
  • David Z.
    • April 1, 2002
    • 182
    Re: C1 Rear Window Run
    Here are some shots of the mount holes on the passenger door of our '60. The driver door needed some pretty good patching to repair broken out glass around the mount holes.
    Hope the pics help a bit.
    Dave Zuberer
