1963 Horn Relay Wiring - NCRS Discussion Boards
  • Gerald C.
    • June 30, 1987
    • 1314
    I have a 63 non-air car and I'm replacing all the wiring. I always take a lot of pictures when I'm disassembling the car for restoration purposes. I did not take a picture on the wiring set-up for my horn relay!!!! (Senior Moment) As the picture indicates, I have a two red wire connection on the right and a three wire (2 red and 1 red/white) on the left. I'm assuming the three wire set up is attached to the "BATT" terminal on the relay.
    Am I correct in my assumption? The wiring diagrams are not very clear at all in showing which goes where.
    Thoughts?
  • Arland D.
    Moderator
    • July 31, 1980
    • 430
    Re: 1963 Horn Relay Wiring
    According to the shop manual wiring diagram, you are correct.
    • James W.
      • December 1, 1990
      • 2676
      Although I have a '64 non a/c car, this is the configuration of my horn relay wiring. The 3-wire connection goes to the battery connection.
      James
      • Gerald C.
        • June 30, 1987
        • 1314
        Thanks for your responses
