Clean/restore Exhaust manifold - L76 - NCRS Discussion Boards
  • Steven K.
    Infrequent User
    • November 18, 2021
    • 16
    Winter blues must be setting in. '65 L76, believe the manifolds are original. Thoughts on best way to clean up or restore? Car is driven, but would look better with them cleaned up.
  • Arland D.
    Moderator
    • July 31, 1980
    • 422
    Re: Clean/restore Exhaust manifold - L76
    Hard to beat sandblasting and shoot with Cast Blast 1200 keeps them looking new for many years on driven cars. If you're not going to remove them, someone else will have to chime in.
      • December 1, 2005
      • 185
      Steven,
      I agree on the sandblastimg to clean the manifolds. I then treated mine with Pre-Lube 6 which is an aerosol spray. There are a number of products out there to treat the manifolds. You can research past TDB posts to research this. That's what I did and then made my decision. Also, original engines had no gaskets between the heads and manifolds. Make sure your mating surfaces are flat and clean. Doesn't hurt to put on a layer of silicone to the mating surface of the manifold when you reinstall. You can wipe off any excess that might squeeze out.
      • Leif A.
        • August 31, 1997
        • 3628
        I had mine ceramic coated several years ago...still look like new and I drive mine 6,000 miles a year.
        Leif
        • Mark E.
          • April 1, 1993
          • 4542
          Two thoughts:
          - From your photo they have a nice original look with minimal rust. If judged, leaving them alone would probably score best.
          - If you want a "just cast" look but don't want to remove them, gently wire brush by hand to remove loose rust and apply Caylx. They'll look fresh but won't score as well if judged.
          Mark Edmondson
          Dallas, Texas
          Texas Chapter
          • Joseph W.
            • February 20, 2022
            • 368
            I just did my exhaust manifolds.
            Media blast clean in my cabinet.
            taped off all the ports.
            Painted with Seymours Cast Blast 1200 followed by 2 hours in the BBQ at 400 degrees.
            1971 coupe LS5 454/365hp
            1969 coupe L71 427/435hp
            1969 coupe L89 427/435hp
            • Mel S.
              • August 31, 1992
              • 264
              After sand blasting mine, I put on POR 15 exhaust colored (gray)paint. That was 4 years ago and still look great.
              • Steven K.
                Infrequent User
                • November 18, 2021
                • 16
                Thanks Mark, you are probably on to something. Long winters in Wisconsin and I'm sure I'm risk of overthinking things.
                • Ed S.
                  • August 6, 2014
                  • 1377
                  Does this product (Seymour Cast Blast) specify / require it to be baked for 2 hours or so at 400 or was that something you decided to do? i looked at the product spec sheet - I could not find info that specified baking like you did. Just curious.
                  Ed
                  • Joseph W.
                    • February 20, 2022
                    • 368
                    Buy part #AP-CGH Body Spray Paint, Cast Blast Cast Iron Metallic, 12 oz Aerosol, Hi-Temp for your classic vehicle from National Parts Depot. Free shipping on orders over $300, fast delivery & everyday low pricing! Order now!
                    The directions stated you cook at 400 for 2 hours. See the link above.
                    • Leif A.
                      • August 31, 1997
                      • 3628
                      [ATTACH=CONFIG]120150[/ATTACH]
                      Joseph,
                      Those came out beautifully. Update us in a couple of years as to appearance and durability.
                      Leif
                      • Bill M.
                        • 1322
                        I wire wheel mine clean. Instal on the car get them up to operating temperature and spray with WD-40. It bakes onto the metal. Spray again every few months. The manifolds look natural. It just stinks while baking. Got this from old cars weekly 30 years ago.
                        • Mark E.
                          • April 1, 1993
                          • 4542
                          Do you really apply the oil when the manifolds are hot? Or do you apply the oil when cold, then start the engine?
                          Mark Edmondson
                          Dallas, Texas
                          Texas Chapter
                          • Bill M.
                            • 1322
                            Mark yes when at running temperature. Do it outside your garage. WD stinks when it evaporates.
                            • Bob I.
                              • November 9, 2006
                              • 265
                              I used POR15, Manifold Gray, three years ago. What I like about POR15 is that you can use a paint brush for touch up.
                              Bob
