Question on transmission main case casting number - NCRS Discussion Boards
  • Justin S.
    • July 3, 2013
    • 305
    Would someone be able to tell me the applications for GM #3915032?
    Justin
  • Gary B.
    • February 1, 1997
    • 7078
    Re: Question on transmission main case casting number
    Justin,
    I found this via a Google search:
    RPO Years Casting 1st 2nd 3rd 4th Spline (Input) Pin Spline
    Saginaw
    M20 67 3915032 3.11 2.20 1.47 1.00 L6 engine
    M20 67 3915032 2.54 1.80 1.44 1.00 V8 engine
    Gary
    • Mark F.
      • July 31, 1998
      • 1608
      Originally posted by Justin Sibbring (58615)
      Would someone be able to tell me the applications for GM #3915032? Thanks, Justin
      Justin,
      The Camaro Research Group says it's for a '67 Camaro...dunno if there were more applications or not.
      My bet is Joe Lucia would know.
      ...The 1967 Camaro main case casting number is 3915032, the extension housing is 3860042, the side cover is 3890527 and the front bearing retainer is 3859033. Note that the 6 cylinder Saginaw 4 speed transmission casting numbers are the same as the V8 Saginaw 4 speed transmission casting numbers. Only the "guts" are different....
      thx,
      Mark
      • Justin S.
        • July 3, 2013
        • 305
        Thank you Gary and Mark.
          • 43287
          Originally posted by Mark Francis (30800)
          Justin,
          http://www.camaros.org/forum/index.php?topic=17376.0
          Mark------
          Yes, the GM casting number 3915032 was used for the cast iron main case of 1967 model year Saginaw 4 speed transmissions. These transmissions were used in lower performance applications for the 1967 model year. These included Camaros as well as other Chevrolet models. NONE were used for any 1967 Corvette. For 1968 and and later, the casting number for these transmissions changed to 3925656. These were also used for lower performance 4 speed applications for many Chevrolet models but never Corvette. They were used through 1975 and, possibly, later.
          By the later 70's the manufacture of the old Saginaw transmission was transferred to the Muncie transmission plant with the original Muncie 4 speed ceasing PRODUCTION after 1974. The Saginaw transmission became a "Muncie" and MAY HAVE changed to an aluminum main case, although not the same as the original Muncie. These transmissions were used in lower performance 4 speed GM applications in the late 1970's and possibly early 1980's. These included 1978 Corvettes with L-48 and some early 1979 Corvettes with L-48. The casting numbers for the main case of these transmissions was GM #3925656, the same as the earlier Saginaw 4 speed.
          The 3925656 main case, GM part #3925654, was discontinued without supercession in January, 1993.
          • Justin S.
            • July 3, 2013
            • 305
            Thanks a lot, Joe.
            • Mark F.
              • July 31, 1998
              • 1608
              Mark------
              Joe,
              Thanks much...I knew you'd know the whole story...
              If you ever get time to write a book on all the stuff you know, lemme know 'cause I'll gladly buy it !
              thx,
              Mark
              • Mark E.
                • April 1, 1993
                • 4609
                Joe,
                This forum is the book, but better because it has a search function.
                Mark Edmondson
                Dallas, Texas
                Texas Chapter
