Valve cover decals - NCRS Discussion Boards
Valve cover decals
  • Gary B.
    • February 1, 1997
    • 7053
    Re: Valve cover decals
    Thanks Bill.
    Gary
    • Dennis C.
      • June 30, 2002
      • 884
      Originally posted by Gary Beaupre (28818)
      Bill,
      For someone like me who has never applied one, can you describe your technique? I did just buy extras, so I can mess up once or twice. but I’m sure there must be some tips in addition to having a meticulously clear surface. Any tools to have handy?
      And how exactly must it be positioned to make the judges happy?
      Gary
      To apply the label, mix some Dawn kitchen soap in a spray bottle with water. Spray the area where the label is to be applied so the entire surface is wet. Carefully lift your label and place it on the valve cover over the wet soap.
      The soap and water mix allows you to slide the label around without tearing. The label will start to stick as soon as the soapy water disapates (typically a few seconds). This should give you sufficient time to property position your label.
      • Larry E.
        • 1692
        #18
        Just an update on my 66 Base Engine Valve Cover Decals. Hope the pictures come out
        OK; not my best camera but it was handy for sure. Used the Water Transfer Type. Used the
        brand name "Micro Set" for the Decal Solution and Cleaner.(Two step process) Picture
        below. The ones before where the "Press ON Stick On Type" that never lasted too long and
        took a hit in the points when car was judged in the "Concours" class. Thanks>Larry
        Larry
        LT1 in a 1LE -- One of 134
        • John F.
          • March 23, 2008
          • 2415
          #19
          Looks good. Hope they last awhile.
