12 Volt automotive wires - NCRS Discussion Boards
  • Ray G.
    • May 31, 1986
    • 1189
    Hello;
    Spoke with a Mechanic friend who repairs diesel and gas trucks and cars including rodent damaged 12 volt wiring.
    He said the most automotive 12V wire cover/insulators are SOY based.
    Consequently the wire insulation cover are food for rodents.
    Can anyone on the TDB contribute to that thought ?
    Thank You for your help.
    Ray
    I hope you dance
  • Gary C.
    Administrator
    • October 1, 1982
    • 17657
    Re: 12 Volt automotive wires
    Ray,
    Soy based automotive wiring IIRC was introduced around 2000 to save money and be environmentally friendly.
    Gary
    NCRS Texas Chapter
    https://www.ncrstexas.org/
      • 15667
      I recall in the early/mid-nineties that Daimler-Benz began using "biodegradable" wiring harnesses, which started failing due to degradation of the insulation when the cars got to be 15-20 years old. I don't know of any other manufacturers that engaged in the same nonsense, but I except others did, And I don't know if the practice continues.
      • Leif A.
        • August 31, 1997
        • 3627
        Oh, it certainly does. In 2007, we opened a new BMW dealership on 26 acres of, what was, open field...former home to many hundreds/thousands of field mice. Almost immediately, we started having issues with wiring harnesses being gnawed on. After awhile, the little f#$%&#$ moved on but not before doing plenty of damage to both new and pre-owned BMWs.
        Good read below:
        https://www.caranddriver.com/news/a2...hink-is-tasty/
        Leif
        • Roger W.
          • January 29, 2008
          • 567
          My neighbor had that problem with his 2012 Lexus. I thought that it was strange that mice would eat wire insulation, until I read an article about the new SOY based insulation. Another "great improvement".
          • Ed S.
            • August 6, 2014
            • 1377
            As others have stated, it is true. It is like a 24 hour salad bar for rodents - they get nutrition from it. The industry switched to the soy based stuff for two reasons, cost and it is allegedly good for the environment. I have heard that some manufacturers have switched to a product that includes a very distasteful material mixed in with the soy based insulation material to deter rodents. Others (Honda for one) has issued TBs that instruct dealers to wrap wires in a tape that contains distasteful materials - a fix if you are having rodent issues. Finally, you can buy tape that has bad tasting stuff in it to deter mice. Just do a google search for "electrical tape to deter rodents". Doesn't it just piss you off - you have to correct a deliberate design flaw that manufacturers built into your car in the name of the environment. I bet the auto industry never tested this stuff before they started using it - like leave a car with soy wires parked in an old garage for a few weeks.
            Ed
            • Richard M.
              Super Moderator
              • August 31, 1988
              • 11323
              My 2006 Silverado had a rodent chew through a plastic vacuum pipe at the fuel tank. Before we found it, it caused a Check Engine code for Emissions fault. It took a long time to diagnose. Those also have Soy base. This was about 7 years ago. That's when I read about Soy based wiring.
              Insurance companies have paid out millions for claims, and manufacturers are responsible if under warranty. They too have repaired these failures on some makes.
              Rich
              • Roger W.
                • January 29, 2008
                • 567
                There are many places in a vehicle with wires that you can't even see, but a rodent can get into those spaces.
                • Dave H.
                  • August 17, 2010
                  • 47
                  Mercedes crappy engine harnesses were 91-96, then they returned to conventional insulation. Lots of wiring replaced. Mine is a 98 that continues daily driving with the orig wiring.
                  • Ray G.
                    • May 31, 1986
                    • 1189
                    Thank YOU everyone for your informed answers.
                    Ray
                    I hope you dance
                    • Richard M.
                      Super Moderator
                      • August 31, 1988
                      • 11323
                      Im hoping reproduction harnesses from Lectric Limited and M&H are getting their wire stock from a "Non-Soybean Based" Supplier.
                      That's a scary thought but it's been on my mind since I learned about this topic years ago.
