Will a Late 69 to 82 steering gear box fit/work on a C2?
I had a C2 rag joint that I restored and sold to a 67 owner. He called me and said that he could not get the rag joint I sent him to tighten up on the gear box input shaft.
Before we did the deal, he sent me a picture and I could easily see that his was for the Late 69 and later C3. I told him at the time that I was not sure how someone got the C3 rag joint onto a C2 steering box, but I assumed they ground out the flat spot on the rag or something.
I happen to have some pieces for C3 rag joints and when I compare them to a C2 rag joint, the lower side, the side that fits to the steering box input shaft, looks to be smaller in diameter than the C2 rag joint. However, I found this in another thread from Jim Shea. early steering boxes have a 3/4-36 spline, and later boxes have a 3/4-30 spline with a flat machined on one side
So my assumption is that it is not possible to get a C2 rag joint to fit to a C3 steering box input shaft. Is it possible the 67 owner has a C3 steering box on his C2?
Don
Don
