DOT 5 compatible caliper o rings - NCRS Discussion Boards
  • Ed D.
    • December 1, 1990
    • 329
    There is a site on e-bay selling o rings for c 3 calipers that he claims are DOT 5 compatible. He claims the rubber is EPDM (see link below) Has anyone had any experience with this product?
    Ed DiNapoli
    CNJ Chapter Past Chairman/Co Founder
    1972 Targa Blue Coupe, Original Owner,
    Duntov Award, Sam Foltz Award,
    Founders Award, NCRS Gallery VIII
    2011 Corvette Convertible
    NCRS Presidents Award 2014
  • Gary B.
    • February 1, 1997
    • 7053
    Re: DOT 5 compatible caliper o rings
    Ed,
    Have you read Patrick Boyd’s recent post on this topic? I’m not surprised someone on eBay is finally offering DOT 5 compatible O-rings.
    https://www.forums.ncrs.org/showthre...on+brake+fluid
    I think Patrick’s posting offers a less expensive way to do front and rear calipers.
    Gary
    PS: Does anyone know the identity of eBay seller “oldvetteman”?
      • 43248
      Originally posted by Gary Beaupre (28818)
      Ed,
      Gary
      Gary------
      The item description which confirms the EPDM rubber material does not specify if it's peroxide cured. In my opinion, that's critical. I would not want to use any seals, standard lip or o-ring, that were not peroxide cured.
        • 11668
        Gary------
        I was surprised the eBay ad didn't mention this specifically, as it seems like whoever wrote it has been reading the discussions on this board.
        • Gary B.
          • February 1, 1997
          • 7053
          • Gary B.
            • February 1, 1997
            • 7053
            • Gary B.
              • July 31, 1979
              • 926
              Has anybody found "Peroxide Cured" master cylinder seals?
              Gary Bosselman
              • Owen L.
                • September 30, 1991
                • 882
                Didn't Patrick's testing reveal practically no difference between the peroxide and sulfur cured EPDM?
                • Gary B.
                  • February 1, 1997
                  • 7053
                  Gary Bosselman
                  Gary,
                  That is the key question. Having DOT-5 compatible caliper O-rings solves only part of the problem. And those with calipers that use lip seals have the whole problem still to solve.
                  Gary
                  • Gary B.
                    • February 1, 1997
                    • 7053
                    • Owen L.
                      • 882
                      Owen,
                      In Patrick’s original thread, I posted this information from a website that talked about the differences between peroxide vs sulphuric curing.
                      Thanks for reposting that Gary -- I had forgotten it. While peroxide is preferable, didn't sulfur-cured perform as well? One more thing, how hot do calipers get?
                      • Gary B.
                        • February 1, 1997
                        • 7053
                        • Patrick B.
                          • August 31, 1985
                          • 2003
                          Owen, I completely agree with Gary. While the sulfur cured EPDM looked ok also in my experiment, Gary's additional information convinces me that all O-ring conversions for calipers using DOT5 should use peroxide cured EPDM. Peroxide cured EPDM o-rings are easy to buy from the oringstore.com, and for less than $3.00 a caliper extra, I think they garrantee that you will not need to do the job twice. That said, I would buy any master cylinder kit that the manufacturer says uses EPDM seals. I don't think you would ever find out the curing process of the seals, and the temperature of the master cylinder is not a factor.
                          • Gary B.
                            • February 1, 1997
                            • 7053
                            • Patrick B.
                              • August 31, 1985
                              • 2003
