1969 Jack Storage Box - NCRS Discussion Boards
  • Kevin S.
    • January 5, 2011
    • 255
    Doing some restoration work on a early 1969 jack storage box and wondering if this hole is factory - normal? Or, did a previous owner drill a hole in the bottom for some odd reason.
    Thanks in advance for your help.
    Kevin
  • Gary B.
    • July 31, 1979
    • 926
    Re: 1969 Jack Storage Box
    The 69 I have here does NOT.
    Gary Bosselman
      • 43287
      Kevin
      Kevin-----
      My original owner, September, 1969 built convertible does not have the hole. My guess is that the hole was added by some owner that thought there was a need for a compartment drain hole.
      • Kevin S.
        • January 5, 2011
        • 255
        Thank you Gary
        • Kevin S.
          • January 5, 2011
          • 255
          Hi Joe,
          Yep, seemed odd to me that a small (roughly 3/16") hole was drilled right next to the larger black plastic cap plug. If they wanted / needed a drain hole they could of just removed the black plastic plug?
          Thanks Joe and Gary for the replies. I'll put it on my list of things to fix. I have fiberglass, resin, white and black gel coat tint so I'll be able to make the small hole disappear. Thanks again for the clarification.
          • Jeffrey S.
            • May 31, 1988
            • 1902
            I know the question has been answered but since I was underneath my 69 I thought I would take photo and send it along. I have a couple of more attachment rivets than yours but I have a factory alarm which has some additional items in the box.
            Jeff
