Unusual 40083 Fuel Pump - NCRS Discussion Boards
  • Larry M.
    • December 31, 2001
    • 535
    I bought a complete used pump on ebay which is an anomaly versus what I've seen or had before. It is from a low miles or early take off based on the condition and has some unusual features.
    1. The stamped part is 40083 consistent with original assembly line versions (no date code letter after the number as seen on service replacements).
    2. But the lower flange does not have the two "reinforcement" bosses which are typical of original assembly line pumps. So it matches a service replacement lower body.
    3. The action arm cross pin has the cross or X on the head as typical for both assembly and service pumps but the opposite end which is normally spread by three "chisel" cuts at about 120 degrees is not cut. It is simply mashed by a press.
    I have owned several of these pumps and have studied them. In my opinion this one has never been rebuilt. So my purpose here is simply to document it for reference by others. It is possible that an assembly top and service bottom have been put together but the compressed end on the cross pin is unusual or unique. The upper diaphragm and lower gasket and original 1960's style and appearance.
  • Alan D.
    • December 31, 2004
    • 2025
    Re: Unusual 40083 Fuel Pump
    Does it have the yellow lines on the diaphragm? What numbers are on the inside?
    Any pictures?
    • Larry M.
      • December 31, 2001
      • 535
      Alan - here are three of 14 pics I have from the ebay listing which I think illustrate the key points I've made, the part number, the cross pin, and the lack of lower bosses. Another pic shows the arm return spring which has significant yellow paint on it. The arm does not operate as I would expect so there is likely an internal failure. Likely an early failure and removal resulting in strong cosmetic condition. I'm pretty sure it has not been rebuilt although one lower cover screw does show some slot damage. I have not inspected it for dates.
      • Alan D.
        • December 31, 2004
        • 2025
        OK, not sure of "2. But the lower flange does not have the two "reinforcement" bosses which are typical of original assembly line pumps"
        Not sure where these are located? Could you educate me a little more, pic is an original one.
        • Larry M.
          • December 31, 2001
          • 535
          OK....so here are two pics of an NOS version of the assembly line configuration. These bosses which cover the 'IN' of "MADE IN U.S.A.' are visible. I have not seen a "40083" only version that did not have them until the one I just bought. I spoke with Don Hooper this morning and he has these on his original pump but doe not on a service pump he owns with the alpha date code stamped next to the 40083. I have several of these pumps which have the bosses.
          Also, I looked at dates: the only ones in the lever arm cavity would be visible and there are none but the part number is there.
          • Alan D.
            • December 31, 2004
            • 2025
            Here are two original pumps, showing the date codes on the inside. The 64 pump I took off in Aug of 1967, the original owner (in same state as me) does not recall replacing it. So these both have the "reinforcement" bosses as one expects however it would be nice to know if the yellow lines were used on rebuilds/NOS ??
