1954 Carter carbs leaking gas - NCRS Discussion Boards
  • Joseph K.
    • July 27, 2023
    • 11
    I just last year bought my 1954 C-1. The carb bottoms have rubber lines mounted on them and joined together to allow gas to leak out onto the ground after shutting the motor off. Is there a fix to not having some excess gas lying in the side draft carbs when shut down?
  • Chris S.
    • January 1, 2000
    • 1069
    Re: 1954 Carter carbs leaking gas
    The lines originally where steel.
    The line set is available repro
    There is a fix for the carb leak - use an updated needle and seat - There is a spring that is installed to keep the needle closed
    1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
    Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
    1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
    1957 Corvette - FI 3 sp - Black and Silver
