1954 speedo gear needed - NCRS Discussion Boards
  • Joseph K.
    • July 27, 2023
    • 11
    Where can i find a replacement gear for my original, 1954 C-1?
  • Mike M.
    • May 31, 1974
    • 8382
    Re: 1954 speedo gear needed
    the drive or driven speedo gear? mike mccagh
    • Joseph K.
      • July 27, 2023
      • 11
      The gear on the speedo cable where it enters the trans. and engages a trans gear.
      • Joseph L.
        • July 26, 2012
        • 162
        You will need to select the correct driven gear based on your rear end ratio.
        The early gear and fitting is on the left.
        Joe
        • Joseph K.
          • July 27, 2023
          • 11
          Joe
          Thank you, Joe! I have the 3.55 hypoid rear gear. Where do I get the reproduction parts from?
          • Joseph L.
            • July 26, 2012
            • 162
            I misspoke about the gear configurations. The earliest PG had a different gear fitting and speedo gear. The PN appeared to have changed for 53-55, and 55-57. Here is the information from the 1929-57 master catalog.
            50-54 Pass w/ PG, 53-55 Corv 6 cyl 39-11 gears (3.55) 3704230
            55-57 Pass, Corv, w/AT, 21 teeth red 3708142
            I found this photo from Jim Lockwood. The fitting screws into the tranmission in those earliest years.
            The long red 21 tooth gear is readily available from several sources. Check your fitting and select according to that. The short fitting on the right will not work in the early transmissions. Neither work in the transmissions with screw-in fittings.
            • Joseph K.
              • July 27, 2023
              • 11
              Thank you once again, Joe! You gave me a lot of info. In spring I'll remove the fitting to see what I have. I've heard that finding the gear for the 6 cyl. 1954 is almost impossible. It seems that no one repo's the part.
              • Guy M.
                • November 1, 1993
                • 500
                I have one on e-bay for $99 if anyone cares. Came out of a 54.
                • Joseph K.
                  • July 27, 2023
                  • 11
                  Guy, I tried to find the listing on Ebay and couldn't find it. What is the exact listing title? Joe
                  • Guy M.
                    • November 1, 1993
                    • 500
                    Hi Joe, try 1954 corvette speedo gear
