Cigarette Lighter issue 1970 - NCRS Discussion Boards
  • Bob H.
    • July 31, 2000
    • 827
    During judging my cigarette lighter not only had the correct Casco tip but would not hold in place until hot. Simple fix I thought. I adjusted the receptacle to add a little more pressure and then the lighter works perfectly. I was going to find and order a casco but discovered I had a new one from years past in my parts pile. I put that one and it would not hold down until hot. It appears when depressing the casco, it does not extend down far enough for the tabs to catch it. Just short and the porcelain barely protrudes! Now I don't know if I need to order another Casco or if the repro socket is deeper than it should be.Theres a photo in the manual of the lighter element holder but can't tell what it looks like inside. Its a Casco 63. When depressed should it extend beyond where the porcellain is seen?
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11366
    Re: Cigarette Lighter issue 1970
    Bob,
    I know that the elements changed to a longer version at some time.
    It seems like your new element may be the shorter version used on the C1 cars.
    Can you see a difference in your 2 elements side by side?
    Can you post a picture of the two elements?
    Rich
    • Bob H.
      • July 31, 2000
      • 827
      Yes Rich. There is a difference. Mine should be a Casco 63 which is shorter. My receptacle is apparently for the longer one so I will have to change it.
