Captive Belt Water Pump to Crank Install - NCRS Discussion Boards
  • Bob H.
    • July 31, 2000
    • 821
    My current repro belt is too loose. I am trying to get the replacement on. What is the best way to do this?
  • Mark E.
    • April 1, 1993
    • 4602
    Re: Captive Belt Water Pump to Crank Install
    For 454, I remove the water pump pulley, reinstall it with the belt on it, then adjust the idler pulley.
    Mark Edmondson
    Dallas, Texas
    Texas Chapter
    • Jim L.
      • September 30, 1979
      • 1816
      This is what I did when I added a redundant belt to my '63 327/300. I don't know any other way.
      • Bob H.
        • July 31, 2000
        • 821
        I should have mentioned this is 70 LT-1. I think it should have the third belt and no idler pulley
        • Leonard M.
          • September 7, 2009
          • 236
          Use Mark Edmondsons instructions for a 454 with the exception of the idler.
          "I remove the water pump pulley, reinstall it with the belt on it" ....(unless you have P/S)
            • 43250
            Bob-----
            The only 1953-82 Corvettes that were ever originally equipped with a belt idler pulley were 1963-65 with L-76/L-84 and 1968-74 big block with C-60.
            • Owen L.
              • September 30, 1991
              • 882
              I take the opposite approach: leave the water pump pulley on the w/p shaft and remove the crank pulley. There's a small registration depression in the balancer that mates with the pulley and that's much easier to get the belt in a vertical position than at the top side. The problem I ran into with working the top pulley is that once it's on the shaft, you can't align the bolt holes because you can't hold the w/p stationary. No such problem with the bottom pulley.
              I've done this with both my 427 non-A/C and my 454 w/AC.
              • Bob H.
                • July 31, 2000
                • 821
                That's what I will do.
