Cigarette Lighter Fuse Holder for 1963 to 1966 Corvettes - No harness modifications
Re: Cigarette Lighter Fuse Holder for 1963 to 1966 Corvettes - No harness modificatio
Here is the distributor for the Auveco electrical products.
Butt connectors Ring terminals Loop terminals Spade terminals Battery terminals Splicers Harness & Pigtail connector terminals
Complete Product Group LLC
d/b/a AutoFastenersAndClips.com
187 Pavilion Pkwy # 297
Newport, KY 41071
Phone: 800-910-372
I placed my order online on Thursday Nov 2 and got it 4 days later, UPS, last Monday Nov 6.
Rich- Top
Richard,
I don't have a C2 but it's fascinating to read how you worked through the design.
I noticed you use a small butane torch for soldering. Do you like that better than an iron? It seems like the open flame could be an issue while working in a cramped space.
And for shrink tubing a heat gun works well.Mark Edmondson
Dallas, Texas
Texas Chapter
1993 Coupe, 40th Anniversary, 6-speed, PEG 1, FX3, CD, Bronze Top- Top
Richard,
The torch works great for heatshrink too, but I mostly use a heat gun for that.
Before I solder the terminal I slip on a rubber insulator. This is how wiring was done originally.
We use both cloth covered and hi temp vinyl jacketed wiring. If we use a original engine, cloth. Modern repower, vinyl, but cloth up to the cockpit instead.
The flame on the Snap-On torch can be controlled down to a tiny flame. This past summer my friend gifted me that brand new SO Torch. I love it.
Some wiring examples of a 1930 Garwood we repowered in August due to reverse applied water injection in it's 350 small block. We replaced it with a new Stroker 383, fully marinized with all new aluminum reverse-elbowed exhaust to prevent water intrusion in the future. Also made our own 3" stainless outlet pipes.
I did all of the wiring. We also added relays and safety switches to kill the engine if loss of oil pressure, along with other features for owner status monitoring. A fun project. I also created a wiring diagram for the owner as it'll be easier for future diagnosis.
Some photos. The day we did lake trials all was perfect. The owner owner was very pleased.Attached Files- Top
Wooden cars and wooden boats display remarkable craftsmanship. Beautiful quality work -- including your wire skills. They all fit together well.
I once got a ride in a Chris Craft on the St. Clair River. I was told the Chris Craft factory was across the river from where we were. That rivals my first drive in a Corvette. Wooden boats are beautiful.Terry- Top
Rich,
They are lucky to have you working on their boat. Beautiful work and very thoughtful to include the wiring diagram.
Gar Wood boats epitomize wooden boat design, quality and beauty. Do you know any of this particular boat's history?
Thanks- Top
Thanks for this information. Being a non-smoker, I have no need for the cigarette lighter to be active. I could just not attached the lighter until I get the car judged, hook it up for judging and disconnect it afterwards. I would put an insulation around the wire until needed.- Top
Thanks Terry & Peter. Boats are in my blood too.
Rich- Top
Wow, we have a 51 Chris Craft off of Lake Winne (sp) I'd butcher it to death. We had a place at Lake Newfound from 1946 until 2003-4 and owned the Chevrolet dealership in Bristol from 59 - 72. My dad's cousin builds lobster yatchs and has a place on an island off the coast of Maine. LOVE the area, but wow it's so cold even in august you can't go in one foot at a time... it's all or nothing!- Top
Then a dead brand new out of the box Repro T3(I paid dearly for) outer headlamp high beam element.
These just knocked me out of 2nd Flight(which I was hoping for), on my '59. It had a '61 Dual WCFB 270HP with original assembly stamp pad and vin stamp, perfectly matched ancillaries, but lost all points for it. I knew that upfront of course. The judges loved the engine though as all the dates fit right in line with it's original car. I found the original car the engine came from 28 years ago but the guy had just restored it with a replacement engine and didn't want the original engine.
I knew it wouldn't ever top flight but a 2nd flight? I'd have been elated getting that. Darn Lighter got me the worst. I'm still mad at myself when I think about it.
I do know that a few years ago it won Best-In-Class at a big ACBS event somewhere, maybe Tahoe I forget.
Bo & Cathy restored this one below years ago also.... Baby Bootlegger, Gold Cup winner in the mid 20's. Poor video. Nice boat. Has its original Hispano-Suiza V8 which was rebuilt.
- Top
Rich- Top
A follow up on the fuse adapter project.
Remember my search for 0.115" pins for creating the Version 2 adapters for the reproduction lighters.
These. Their OD is 0.126 and I thought it may work. I found a small pin, 0.126" in diameter in my misc pile of bits and tried to insert it into the stock power connector in the Main harness. It did not.
Back to the drawing board again. I got wrapped with other tasks and finally got back to the search, for days. Finally I decided to go to my Napa to check the shelves over. No luck, then I showed what I needed for the pin to the store manager. He looked at his catalogs and we perused through through them and found a few candidates. We then went back to the shelves and found several pins but not the right size, too small, Then we found a female pin with a OD that looked like it might work. I had my caliper with me. The OD is precisely 0.115" diameter, matching the lighter housing barrel pin. This is it - Napa #725171.
I test fit several in my Auveco female clips and the fit was perfectly snug. This morning I went ahead and made up a adapter with the Auveco female clip and the Napa pin and tested it several times. It worked fine.
Technically, this will work for either the original or the reproduction 1963 to 1966 lighters.
Rich- Top
