1963 Lighter Not Popping Out - How to Adjust? - NCRS Discussion Boards
+ More Options
Posts
  • Frederick H.
    • August 31, 1983
    • 471
    Is there an average time that the Casco lighter is supposed to pop out when it reaches X temp? It is not popping out currently. I also found that I need to remove the bi-metal piece in the housing to prevent a short (since the lighter circuit is not fused). When I push the element all the way in, it comes back a short distance - maybe need to remove housing and adjust the clips?
    Thanks in advance.
  • Frederick H.
    • August 31, 1983
    • 471
    I didn't title my previous post on this very accurately - really wanting to know how to adjust the lighter housing to allow the element to pop out when it reaches correct temp. Also, any info on removing the bi-metal piece in the housing to avoid shorting in the harness?
    Thanks in Advance.
    • Gary B.
      • February 1, 1997
      • 7060
      • Richard M.
        Super Moderator
        • August 31, 1988
        • 11355
        Re: 1963 Casco Lighter Not Popping Out
        Frederick, Advance search lighter, Titles Only.
        This one "pops" up....(get it?)
        Edit... Another good one Here
        Rich
        • Mark E.
          • April 1, 1993
          • 4606
          If you don't smoke and the car won't be judged, the lighter makes a great kill switch. Just run a lead between the lighter and the negative side of the coil.
          Mark Edmondson
          Dallas, Texas
          Texas Chapter
          • Frederick H.
            • August 31, 1983
            • 471
            Thanks Guys - gotta remember to check the archives! Good photos in there.
            Thanks!
            • Frederick H.
              • August 31, 1983
              • 471
              Thanks Mark but I do plan to have it judged. Trying to find the in-line fuse that has been mentioned in other discussions that does not require cutting into the wiring harness.
              • Alan D.
                • January 1, 2005
                • 2052
                see https://www.forums.ncrs.org/showthre...t=fuse+lighter
                • Frederick H.
                  • August 31, 1983
                  • 471
                  Yep - saw the threads about the Casco's but can't find them on eBay or anywhere else at the moment. Thanks though.
                  • Gary B.
                    • February 1, 1997
                    • 7060
                    • Richard M.
                      Super Moderator
                      • August 31, 1988
                      • 11355
                      Gents, I have some old 66 & 67 main harnesses. I'll take a look and see if I can come up with a inline fuse adaptor using the special round female connectors.
                      This would be removable for judging.
                      Rich
                      • Gary B.
                        • February 1, 1997
                        • 7060
                        Rich,
                        That would be a great service to us! Thanks
                        Gary
                        • Frederick H.
                          • August 31, 1983
                          • 471
                          Rich, that would be outstanding if you could find 'em.
                          Many Thanks!
                          • Richard M.
                            Super Moderator
                            • August 31, 1988
                            • 11355
                            Ok so curiosity got me. I found a '67 harness. I forget, is this the one for '66 also?
                            • Frederick H.
                              • August 31, 1983
                              • 471
                              Took a photo of the connection earlier and although I can't see the backside, it looks to be the same as yours. I think the only difference is that the '67's had the fuse protection.
