LUK 04-049 clutch kit - NCRS Discussion Boards
  • Patrick B.
    • August 31, 1985
    • 2003
    I am trying to find the best currently available clutch equivalent in clamping force and quality to the original clutch of my 70 LT-1. I have seen recommendations of LUK clutches here because they are made by an OE supplier. The 04-049 part number is supposed to be an 11” clutch with a 10 spline disc. But when I enter my car description in Summit, Rock Auto and other seller web sites, they warn that it does not fit my car. Rock Auto seems to think 70 Corvettes have 10 1/2 “ clutch’s. Even when I enter 67 427 Corvette which should definitely call for an 11” clutch, the web sites say it does not fit. Has anyone here used this part number clutch. The GM parts book lists the stock 11” clutch has having about 2600 lb clamping force. In stumbling around the internet pursuing LUK clutches I may have seen the mention of 1700 lb clamping force, but I can’t find it again. Could it have that much less clamping force than an original clutch?
    • 43247
    Re: LUK 04-049 clutch kit
    Patrick------
    Well, they're all correct about the LUK 04-049 clutch kit being incorrect for your 1970 LT-1 assuming that your LT-1 is part of the ZR-1 package. However, if your LT-1 is not part of the ZR-1 package, then the 04-049 is the correct kit and it will work just fine.
    For some reason I've never figured out, there is a lot of misinformation out there regarding clutches for 1969-74 Corvettes. However, it's actually like this: ALL 1969-74 Corvette small blocks, except ZR-1, were equipped with a 14" flywheel and 11" clutch. Only ZR-1 was equipped with a 12-1/2" flywheel and 10.4" clutch ("sort of" LUK 04-021). You can take this info "to the bank".
    By the way, I should have mentioned, the original pressure plate assembly was GM #3893236 and after December, 1971 GM #3884598. The clutch disc was GM #3908960.
    All 1970 and earlier clutch friction discs were 10 spline. All 1971 and later clutch discs except 1978 L-48 were 26 spline. The LUK 04-049 kit has a 14" friction disc with 10 spline.
    Last edited by Joe L.; October 24, 2023, 01:14 AM. Reason: add last two paragraphs
    • Peter M.
      • May 30, 2013
      • 359
      Pat,
      I have the 04-049 in my 67. I have had no problems with it.
      Just a FYI, the throughout bearing that comes with it is some type of composite material.
      Kind regards
      • Patrick B.
        • August 31, 1985
        • 2003
          • 43247
          Originally posted by Peter Miller (58508)
          Pat,
          Kind regards
          Peter------
          The 04-049 the right one for 1967 big blocks (except L-88). It's not the right one for 1967 small blocks.
            • 43247
            Thanks Joe and Peter— I have heard that the composite TO bearings work fine, but I have an all steel made in USA 1 1/4” TO bearing I plan to use with it. I hope there is no reason an old style bearing will not work.
            Patrick------
            The old style release bearing will work fine with the LUK clutch.
            • Peter M.
              • May 30, 2013
              • 359
              Joe,
              Yes, I should have specified my car is a 390 hp 427.
              Kind regards
              • James G.
                • August 22, 2018
                • 800
                Patrick,
                I have used LUK on at least the last 5-6 stock replacements or restorations and have zero issues with them.
                The centerforce clutch is the one I always use if I am looking for a streetable HIGH performance clutch with max clamping force. Not cheap- at least double the LUK, but well worth the money if you are running something which needs a really high clamping force.
                James A Groome
                1971 LT1 11130 - https://photos.app.goo.gl/zSoFz24JMPXw5Ffi9 - the black LT1
                1971 LT1 21783 - 3 STAR Preservation.- https://photos.app.goo.gl/wMRDJgmyDyAwc9Nh8 - Brandshatch Green LT1
                My first gen Camaro research http://www.camaros.org/forum/index.p...owposts;u=4337
                Posts on Yenko boards... https://www.yenko.net/forum/search.php?searchid=826453
                • Patrick B.
                  • August 31, 1985
                  • 2003
                  James- I already have a McLeod street/strip clutch which has been with the ZL-1 for almost 40 years. It works fine but it takes so much petal force that I am ready for a stock clutch when I re-install the LT-1.
                  • James G.
                    • August 22, 2018
                    • 800
                    Thats the thing with the Centerforce, my 110 pound ex-wife could easily push it in.
                    James A Groome
