'53-55 battery tray - NCRS Discussion Boards
'53-55 battery tray
  • Peter R.
    • June 19, 2011
    • 233
    '53-55 battery tray
    The battery tray in my '54 is getting somewhat thin due to corrosion. See picture (after I applied rust converter). I've been looking online for an accurate reproduction. The NCRS manual specifies the ribs you see in the photo. I haven't found any reproductions for the '53-55 Corvette with the ribs, even though some suppliers state that their tray is an accurate reproduction of the original part. I have found, however, that Goodmark makes a battery tray for the 6 volt battery in the '53-54 Chevy passenger car that is identical to the tray in my car except for the attached mounting structure under the tray. Does anyone know of a supplier offering a truly accurate battery tray for the '53-55 Corvette that includes the ribs? If not, I am very tempted to buy a passenger car tray and modify it by adding the Corvette mounting structure.
    Pete
    1954 Corvette #814
    1957 Corvette #646 -- FI, 3-speed
  • Chris S.
    • January 1, 2000
    • 1068
    Re: '53-55 battery tray
    Pete
    Couple things
    C Central used to sell a repro tray - the issue with it was the bottom was flat and not ribbed
    When we judge - that is one item that is looked for is the ribbed bottom
    I am currently working with C Central to make an accurate repro tray for the 53 54
    They scanned a very very nice original tray and we are working on making a nice repro
    I am not sure when it will be ready
    Yes - There are repro trays out there with no legs
    They are not very good - at least the ones I have
    They are also for a Pontiac
    The ribs are not well pronounced and the edges of the tray would need to be trimmed to look right
    The ends need some t******* as well - the edges and side are long.
    Its an ok repro but you can tell its a repro
    1 big issue is spot welding the legs to the bottom
    If one had an spot welder you could make one
    I have original trays and you would have to drill out the welds and transfer over the legs
    Only other option is to try and find a really nice tray which is hard since they all get corroded
    Chris
    TiN Restorations
    1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
    Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
    1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
    1957 Corvette - FI 3 sp - Black and Silver
    • Peter R.
      • June 19, 2011
      • 233
      PM sent to Chris.
      Pete
      1954 Corvette #814
      • Gary B.
        • February 1, 1997
        • 7068
        Pete,
        Gary
        • Chris S.
          • January 1, 2000
          • 1068
          I am working with C Central on an accurate repro
          • Gary B.
            • February 1, 1997
            • 7068
            • Wes S.
              • May 31, 1982
              • 209
              Hope that won't be made in China
              • Peter R.
                • June 19, 2011
                • 233
                Well it took me more than a year to follow through on my plan, but I finally did. I bought a reproduction battery tray intended for '49-54 full-size Chevy. It is virtually identical to the '53-55 6-volt battery tray, except for a bracket extension above the tray. My original tray has a number of holes in it due to 70 years of acid-induced corrosion. Using a cut-off wheel, I removed the bracket above the tray. Then on my original tray assembly, I used a 3/16" drill bit to drill out the spot welds. Using a MIG welder, I "plug welded" the two original brackets to the bottom of the new tray. Using an air die-grinder with 2" sanding disk, I sanded the welds flat. I painted the entire assembly semi-gloss black. Given the continued unavailability of an accurate reproduction of the '53-55 6-volt battery tray, I think it turned out pretty nice and should be good for another 70 years (maybe longer, as new batteries are probably less leak-prone). By the way, the new repro tray is not made in China; it's made in Taiwan.
                Pete
                1954 Corvette #814
                • Leif A.
                  • August 31, 1997
                  • 3653
                  Pete,
                  Very creative and very nicely done!!
                  Leif
                  • Don H.
                    Moderator
                    • June 16, 2009
                    • 2282
                    Pete, that's a Faan - Tastic piece of work.. I bet that would fly through judging without a hiccup!
