C2-Suspension/Steering/Alignment Questions - NCRS Discussion Boards
  • William G.
    • December 1, 1988
    • 138
    Nothing, recently at any rate, has frustrated me more than lower ball joints, toe-in alignment, and steering issues.
    I've recently read many posts on this (these) subjects and find that I still have questions.
    Duke Williams (and others, I'm sure) have stated that when measuring/setting toe-in what is first needed is to establish the longitudinal center line of the vehicle and then measure outwards from that center line to establish a parallel string line on each side of the car for use in establishing the desired toe-in. While I'm sure this could well be the proper way of doing this it appears to be quite difficult to do accurately and an alternative would be to merely consider that on C2s the track is 3/4 (0.8) inches wider in the rear as opposed to the front. Use that fact to establish a parallel string line on each side of the car (i. e,. on each side the front road wheel would be 3/8" further from the string line than the rear. Now I realize that these cars were built with a permitted tolerance (usually plus and minus) which is going to affect the accuracy of the string lines given the individual tolerances present on any given vehicle. However, it would appear that the same inaccuracies would occur with the center line method given that establishing the center line would also necessitate taking measurements from known points such as suspension attachments. I'm not sure I can see that one method is likely to result in greater accuracy than the other and the second method is far easier.
    I have a book on steering/suspension/alignment procedures (not specific to any one vehicle or model) which states that when setting toe-in it must first be ascertained that the tie rods are exactly the same length else the steering geometry will not be the same on a left turn versus right turn. This requirement seems a little odd to me given the tie rods are certainly not going to be the same length after setting the toe. Has anyone determined what the tolerance on tie rods lengths should be?
    It would appear to be far more important to get the toe-in set the same on both sides, have the vehicle track straight down the road, have the steering wheel centered when traveling a straight road and ensure that the steering box is on high point. When I have the toe-in set as I believe it should be (about 1/16" on each of the four wheels) the tie rods (at the front) vary in length by about 3/16 of an inch. Any comments as to whether this difference seems excessive? I cannot seem to locate a stake mark on the worm shaft on the end where the rag joint attaches. At present, I'm reluctant to remove the steering box or pull the steering shaft into the cockpit to gain a better look at the end of the shaft on the upper side of the box. The steering wheel stake lines up with the stake on the upper end of the steering shaft and the stakes are at the 12 o'clock position when the wheels are straight ahead, and the steering wheel turns through 1 3/4 turns each way (which would seem to indicate that the steering box is on high point) or 3 1/2 turns lock to lock. Six hundred thirty degrees of steering wheel movement and a 20.2 to 1 steering ratio would allow the road wheel 30 degrees max. in a turn. I see nothing wrong here.
    I'm certainly not young any longer (who is?); however, the car is definitely not happy negotiating a curve. It tracks a curve FAIRLY well at the posted speed limit but ANY attempt at a faster speed requires excessive steering wheel correction at speeds which should not necessitate any correction. I'm not young anymore but its not me, its the car.
    As pertains to the above comment my belief is that the lower control arm bushings could use replacement and I feel this is having an adverse effect on the toe setting and hence the rear, in a curve, cannot track the front as it should. Finally, I've never read in the archives as relates to lower control arm bushings and specifically ball joint separation, but has anyone separated the upper part of the ball joint from the control arm as opposed to separating the joint from the knuckle, tried grinding the head of the rivets off and unscrewing the upper nut from its stud. This would save the original ball joint as opposed to destroying it by removing by way of separating lower stud from knuckle.
    Any thoughts would be much appreciated.
    Bill
    • 15667
    Re: C2-Suspension/Steering/Alignment Questions
    You appear to have some misunderstandings.
    You only need to draw a string along the longitudinal centerline of the car to measure REAR toe. The centerline is established by carefully measuring at each crossmember, then run the string with suitable plumbobs along this line to establish the string height at a level that you can measure from the center of the tire treads to the string with a tape measure without it interfering with any vehicle components. This line will obviously be below axle centerline, so the actual toe measurements will be slightly more than your indicated measurements, but they'll be in the ballpark.
    Of course the car must be at normal ride height. It can be done on the ground, but a drive on lift is lots easier.
    Also, take the front and rear measurements at the same tire tread point. Whether you start at the front or rear tread faces mark the spots, take the measurements on front or rear tread face, then roll the car the shortest distance to get the mark at the right level on the opposite tread face to take the measurements.
    If you think the rear toe is pretty close and are certain that there is sufficient shim stack on each side, you can usually get it in the ballpark by swapping shims on each rear wheel inside to outside or vice versa as required. I started a thread on this a couple of years ago. Subject '67 L-71 Coupe handled like it was possessed by the Devil, wanting to swap ends even with a mild left steering input. I suspected the RR had toe-out rather than toe-in. (This three-link suspension design is EXTREMELY sensitive to rear toe.) The owner had it set up on a state-of-the-art alignment rack to take measurements ONLY, and, sure enough the right side had a bit of toe-out rather than toe-in. I computed that swapping 3/32" worth of shims from the inside to outside would give us about 1/32" toe-in which was pretty close to what was on the left side.
    https://www.corvetteforum.com/forums...-distance.html
    You know the total shim stack is okay if you loosen the trailing arm pivot bolt at normal ride height and cannot remove the shims with your fingers, assuming they're not seized due to corrosion. A proper shim stack MUST have a slight bit of interference fit, requiring the last shim, a thick one to be tapped in with a small hammer. Otherwise there is a good chance that the shims will be lost on those models that have slotted shims without a safety cotter pin securing the shims to the frame.
    Since this car had only 16K original miles I figured this error was probably from the factory. Maybe the operator got the inside and outside shim stack mixed up. We'll never know. A couple of years later the owner sold the car on BaT. I drove the "Palos Verdes Hillclimb" video in a very sporting matter, and it handled like an angel on the repro Kelsey Goodyears. It sold for $250K.
    The front will always self-center while driving to yield equal toe on both sides. The trick is to get the steering wheel straight. When set up properly the front tie rods should be about the same length. This is a guide. Usually I set the total toe within the range I want with the steering wheel set straight, then if the steering wheel is slightly cocked off-center on the test drive I tweak one tie rod until the steering wheel is centered and the total toe is still within the range I want. It may take more than one try.
    For radial tires keep per wheel toe-in at about 1/32" for a total of 1/16" on each end. For bias tires a bit more is okay, up to 1/16" per wheel, which is 1/8" total, but in my experience radial tire toe settings are okay for bias ply tires, too.
    • Dennis D.
      • March 1, 2000
      • 1071
      Duke...
      I recently made some changes effecting alignment. Installed a rebuild steering box with an exact top lash location. Also installed a tilt column. Both components are in line with one another. Problem is the steering wheel is now off center .
      When you mention tweeking a tie rod, are you only doing one, and is the pitman side the one you tweek?
        • 15667
        First thing is you should verify that all index marks are aligned as called out in the AIM and applicable service manual, and it sounds like you've done that.
        As far as tweaking a tie rod to get the steering wheel straight, I'll give you an example.
        Lets say you get the total front toe a bit under 1/16" toe-in, and the steering wheel is cocked a couple of degrees to the RIGHT.
        So with it straight, the car will steer slightly to the left, and you have two tie rod tweak choices to straighten the wheel.
        1. Shorten the right tie rod, which will increase toe-in slightly
        2. Lengthen the left tie rod, which will decrease toe-in slightly
        Since the the toe is slightly under target, pick the choice that increases toe slightly, which is number 1. You measure total toe and now it's slightly over 1/16" and a test drive shows that the wheel is still slightly cocked to the right, but only about half as much as initially.
        So now lengthen the right tie rod, which will further move the steering wheel back to dead center and decrease toe-in slightly, which is number 2.
        Test drive and readjust as necessary. It may take several tries to get it right if you're new at this. I make simple sketches and keep track of each change on a writing tablet on a clipboard.
        Make sure you know which way to rotate the tie rods to lengthen or shorten, and it's a good idea to annotate your AIM and/or service manual for the next time that may be years in the future.
        When I say "tweaking" I'm talking about about 1/16 to 1/4 turn of the tie rod. It depends and is somewhat trial and error until you get the "feel" for how sensitive a tie rod change is on each vehicle.
        The above applies to "rear steer" cars like the Corvette where the steering linkage is behind axle centerline. "Front steer" cars like seventies H-bodies (Vega, Monza...) where the steering linkage is ahead of axle centerline will be the opposite in terms of tie rod length change effects on toe.
        • Dennis D.
          • March 1, 2000
          • 1071
          Perfect. Thanks Duke
          • Tim S.
            • May 31, 1990
            • 704
            I didn't realize that was you in the video. I saw the owner (at the time) gave you props in his Restorer submission. I giggled like a little kid watching a Duntov car getting wrung out a bit. Well done!
            Tim
              • 15667
              Thanks, Tim. Hector's L-71 was really a sweet ride! In case anyone missed it.
              Bid for the chance to own a 1967 Chevrolet Corvette Coupe L71 427/435 4-Speed at auction with Bring a Trailer, the home of the best vintage and classic cars online. Lot #66,698.
