Rag Joint Bolts - NCRS Discussion Boards
Rag Joint Bolts
  • Thomas S.
    • February 7, 2016
    • 621
    Rag Joint Bolts
    The bolt on the top is from my 63 rag joint which has the correct casting numbers on each half, correct bolts and rivets and assumed to be original. The cleaner bolts are off of a "refurbished" joint that also has the correct casting number on both halves and the correct fasteners.
    are all 3 bolt heads correct?
    67 427/400 Lynndale Blue Corvette https://online.flippingbook.com/view/750924569
    • 6960
    Re: Rag Joint Bolts
    Tom,I think all the bolts in pic are correct, I believe those bolts with 12 points are specific for the Rag joints and I believe the length is also specific to.
