61 FI Plenum To Adapter Plate - NCRS Discussion Boards
  • Mark S.
    • July 31, 1983
    • 666
    A close friend helped with the rebuilding of my 61 low horse FI unit. Are there thin small washers that can be put under the nuts that fasten the plenum to the adapter plate to prevent the galling of the aluminum? Also, I am in need of 10 - 28 one-inch long filister screws that went missing. I tried calling John DeGregory; however, there was no answer. I hope that he is okay. Thanks! Mark
  • Dan H.
    • July 31, 1977
    • 1372
    Re: 61 FI Plenum To Adapter Plate
    Mark, I used washers under the nut on my 59 FI, missed removing one once, it went into an intake port, had to remove the head to retrieve it. Don't recommend to use them, not necessary.
    Dan
    1964 Red FI Coupe, DUNTOV '09
    • Don H.
      • December 1, 1981
      • 1501
      I use "AN" washers under the plenum nuts and under the adaptor plate (intake) bolts. They are very small and hardly show and as you said they prevent galling. I can help you with securing some and filister screws, email me. dynodonh@gmail.com
      • Mark S.
        • July 31, 1983
        • 666
        Thank you very much for the information!
          • 43290
          Mark-----
          Use flanged nuts. These will prevent any possibility of the problem that Dan describes. Plus, they will be no more obvious that using standard nuts with washers.
          • Jim L.
            • September 30, 1979
            • 1817
            Small, stainless steel AN washers are available from the hot rod supplier, Jegs. I recommend their use to prevent the nuts from digging into the aluminum.
            • Mark S.
              • July 31, 1983
              • 666
              Thanks again for the info!
              • Leo G.
                • August 31, 1987
                • 116
                Mark
                I have eight AN ss washers that have your name on them if you are still looking. Pm me with your address and I will put them in the mail.
                Drive em safe
                Leo
                • Mark S.
                  • July 31, 1983
                  • 666
                  Leo:
                  Thank you very much! I have a person helping me; and if there is an issue, I will let you know. I appreciate your offer. Mark
