Shifter stalk wiggle - NCRS Discussion Boards
  • Keith M.
    • January 17, 2021
    • 688
    My 69 shifter stalk has some wiggle between the stalk and the lower square section. I do not weld but have a friend who does. Do you think a spot weld of sorts is the best fix? Any guidance I should give him if so??
    late Oct 1969 L46 350/350, M21 4spd, 3.70 posi convertible --As with life, restoration is a journey, not a destination. Though restored cars provide both journeys AND destinations!
    • 43250
    Re: Shifter stalk wiggle
    Keith------
    I think I'd go with a new shifter assembly. Excellent reproductions are available.
    • Mike T.
      • January 1, 1992
      • 568
      Keith - Back about a dozen years or so, I decided to start taking my cars out to the Wednesday Night Drags at Sears Point Raceway (Norcal) and after a while, I noticed the same slopiness (sp) in the factory Muncie shifter handle. With side exhaust it was easy to remove the shifter assembly and I found the same thing, the upper round shifter barrel had gotten a bit loose from the lower squared section. I cleaned it off and added a couple decent welds to it and it's been fine ever since. The boot covers the welded area so it's not visible.
      Mike T. - Prescott AZ.
