Bolt Size for #4 Body Mount
Re: Bolt Size for #4 Body Mount
Thanks Joe,
I need to expand my library to include those Chevrolet Specifications.- Top
Since Jerry brought up this post, and got his answers, but since it further expanded with more info, I just so happened to find a box of original hardware from a 67 body off from a few years ago.
Images with measurements included. I call them #1,2,3,4. #4 being behind the rear wheels.
#1
#2(at the firewall)
#4 (the other one had to bu wizz-wheeled off)
Parts_4C_16.jpg- Top
Gary, When I get home I'll have to check my photos. I have about 3,000 of that restoration on the laptop backup drive.
Rich- Top
Note the #4 bolt in Rich's pictures does NOT have a pointed end like the other three. Me thinks it may be original but not NTFP.Leif
Top Flight 2017 Lone Star Regional- Top
Gents, Here's the story after seeing my photos of the prep to lift the body off.
I had to cut heads off from BOTH #4 bolts to get them out. The longer bolt that I said was #4, is not. It's a Grade 8, and had 2 washers under the head. Now I'm unsure where it came from, but it came from the car somewhere.
#4 Left had 2 shims.
#4 Right had 6 shims.
After cutting the heads of the #4 bolts, the washers were junk so I tossed them along with the cutoff bolts.
There were a total of 25 shims under the body. There are 17 shims leftover(a few were stuck together in the photos), but I recall I used several media blasted refinished shims back on the frame along with the repro LIC kit. I replicated the original shim count going back on.
Here's my shim map. 25 total.
Here's a photo of the #2 bolt when I removed it. I think I'm missing those two convertible-only #2 mount bolts in my collection because I may have reused them on the car since they're hidden. I can't recall if the kit I had included them. Maybe not and the reason I reused the originals.
A few more photos of the bolts.
I'm still uncertain where that Grade 8 came from now, but definitely not the #4 mounts. It's tip is flat as you can see it standing up by itself in the center of the photo.
===- Top
Sure Bob, I've a a date back in the shop tomorrow so I'll get the ruler and caliper out then. I'll get OD, ID, and thicknesses.
Edit... Gary I'll measure everything I have, except for those thin ones at #4 which I hacked to pieces with the cutoff wheel.
I do remember a thread some time ago talking about these washers too. I'll poke around the archives later.
Rich- Top
