Rear Seal - NCRS Discussion Boards
Rear Seal
  • Brian D.
    • October 2, 2011
    • 7
    Rear Seal
    I have a 1965 327 L76. Rear seal leaking is it difficult to replace?
    • 43277
    Re: Rear Seal
    Brian------
    Not too difficult, at all. Follow the procedure in your Factory Service Manual. Use seal GM #10121044. However, if there is ANY grooving of the seal's journal on the crankshaft, you will need to use an aftermarket seal with an offset lip.
    • Brian D.
      • October 2, 2011
      • 7
      Re: Rear Seal
      Thanks for the info, offset lip good tip
