1953-55 soft top hinge area cover - NCRS Discussion Boards
  • Peter R.
    • June 19, 2011
    • 233
    In a separate thread I've been seeking information on the latches used on Plasticon hardtops for the '53-55 Corvette. That search may have revealed a surprise about my '54. Rob Musquetier in the Netherlands (Corvette C1 Registry) has been very helpful in sending me pictures of his Plasticon hardtop latches and how they attach to his car. One picture (see below) shows where a hole was drilled to accept the hook on the end of the rear latch. I compared that picture to my car and found that I might be missing the piece that had the hole drilled in it (see below). I see that same piece shown in the NCRS 1953-1955 Corvette Assembly Instruction Manual. In the drawing from the Manual (see below), the part is labeled as "3706397-8 L. & R. BRACKET BODY REAR PANEL TO MOULDING - R.H. SHOWN." There is no discussion of this part that I can find in the NCRS '53-55 Tech Info Manual and Judging Guide.
    My question is: Did all '53-55 Corvettes have this piece, or was it a running change possibly made in the 1954 model year? In other words, is my car (1954 #814) missing this piece (on both sides of the car) or was my car made before the factory started installing this part?
    I'm going to guess that that answer is that the part is simply missing on my car and that all '53-55 had this part on both sides of the car. Without this piece, there is an ugly gaping opening showing that is not covered by the seatback. And it's starting to look like I will need a pair of this part in order to mount the Plasticon hardtop in the intended manner.
    Pete
    1954 Corvette #814
    1957 Corvette #646 -- FI, 3-speed
  • Chris S.
    • January 1, 2000
    • 1068
    Re: 1953-55 soft top hinge area cover
    Couple answers here for you.
    The 53 and early 54s have a "flipper" type conv top - the top comes up thru the body and the body is covered with a flipper moulding
    The flipper area is braced with a brace in the top photo - there is also another brace that it is bolted to on the gas tank seat back area
    I have photos of how the braces are installed
    The bottom photos they are missing. (your car)
    You have 814 which is a very early car 713 car built in 54
    If you need the braces I have extra
    In mid 54 they changed the top and thus the moulding and the body at the conv top area
    This top carried over to 1955
    Chris
    TiN Restorations
    Plano IL
    1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
    Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
    1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
    1957 Corvette - FI 3 sp - Black and Silver
    • Dan L.
      • November 10, 2008
      • 82
      Here’s a pic of the bracket on my ‘54 #3299 (R side) and the flipper. The left side is similar.
      I don’t have a Plasticon top.
      DAN
