63 window sticker - NCRS Discussion Boards
63 window sticker
  • Sandro C.
    Infrequent User
    • September 22, 2023
    • 6
    63 window sticker
    Hi new to NCRS.. Looking for help on widow sticker, build sheet location and any other documentation for my 63 Vette 4spd, 327 CE motor which i think is a 300HP (iron intake) ect... but the previous owner said it came with a 340HP vin#30837S100068
    Any help would be appreciated
    Thank you all..
  • Mark F.
    • July 31, 1998
    • 1597
    Re: 63 window sticker
    Originally posted by Sandro Covello (70727)
    Hi new to NCRS.. Looking for help on widow sticker, build sheet location and any other documentation for my 63 Vette 4spd, 327 CE motor which i think is a 300HP (iron intake) ect... but the previous owner said it came with a 340HP vin#30837S100068...Any help would be appreciated...Thank you all..
    Hi Sandro,
    Welcome to the TDB !
    Looks like you have a very early '63 - #68 off the line !
    Short of asking the previous owners more questions about if they have documents they haven't passed along, another way to find out if NCRS has documentation pertinent to your car is to click on the link below and review the Document Service options they present there.
    You can get a shipper report which will tell you the day your car was shipped and the dealer it was shipped to
    For original documentation you have in your possession, you can have those documents validated.
    NCRS | Utilize the National Corvette Restorers Society (NCRS) Historic Document Service to access original Corvette production records. Authenticate your Corvette with factory documentation and enhance its historical value.
    As for the window sticker, build sheet and options the car originally came with - NCRS does not have copies of those, but as stated above can validate some of them if you are able to find originals for your car and ask for the validation service.
    Good luck !
    thx,
    Mark
    • Patrick B.
      • August 31, 1985
      • 2012
      If the car still has the original tach and oil pressure gage, and red line is 6500 with an 80 psi oil pressure, that would be consistent with the previous owner's story. Lower numbers would indicate an original 300hp or 250hp. Also remove a valve cover and look at the casting date of the head. If the head is early enough to be original, it may be. The casting number of the head would be another clue to the original engine.
        • 15706
        The 80 psi oil pressure gage with 340/360 HP engines was not installed until very late in the '63 model year when the oil pump pressure relief spring was changed to 55-60 psi, hot at 2000-up. Prior to this change the oil pressure gage for all '63 engines was calibrated to 60 psi and nominal hot oil pressure was 40-45 psi at 2000-up.
        The 250/300 HP engines are equipped with a tach that has a redline beginning at 5300 and 6500 on 340/360 HP engines.
        250 and 300 HP engines have different inlet manifolds and carburetors.
        One is very unlikely to find any paper anywhere in/on a '63. The "tank sticker" glued on to the top of the fuel tank did not start until the '67 MY.
        You should procure the following documents unless you received them from the prior owner
        1. 1963 Corvette Owner's Manual
        2. 1963 Corvette Shop Manual
        3. 1963 Corvette Assembly Instruction Manual (AIM)
        4. 1963 Chevrolet Corvette Vehicle Information Package (free download from www.gmheritage.com
        If you plan on having your car judged, procure all the applicable NCRS judging manuals and score sheets.
        • Sandro C.
          Infrequent User
          • 6
          Wow! Thank you all... great info for me to read through.. yes it was #68 off the line and i do have documents stating it is the 1st coupe to come to Canada..
          Here is a picture of the gauges looks like the previous owner was correct on having a 340hp
          motor..
          i will look all the info and sure to be back with more questions.
          Thank you all again.
          • Danny P.
            • June 30, 2002
            • 344
            Order a shipping report from NCRS and the information on the report try to match the shipping on your window sticker if the same ,like Patrick said check the casting date on cylinder heads, and block and stamp Pad see if everything lines up
              • 15706
              I recall that documents for cars shipped to Canada for retail sale can be obtained from GM Canada, but don't recall the details or how to obtain them.
              • James G.
                • August 22, 2018
                • 808
                Ordered without a radio it appears.
                The Canadian docs will give you the complete list of options installed on the car when it was built.
                I love L76's.
                • Sandro C.
                  Infrequent User
                  • 6
                  yes it is a radio delete but the weird thing is that they installed an antenna..
                  i do have GM Canada documents from previous owner but i plan on asking for an updated one and hope i can get more info..
                  Thanks all..
                  • James G.
                    • August 22, 2018
                    • 808
                    If you have the Canada docs then you have them, UNLESS you have the OLD OLD formatted sheets which included other cars shipped to Canada then you will not get anything new.
                    If you have copies of the OLD Green computer sheets which have the options listed horizontally across the sheets then by all means order new Candian docs as the format was updated at least 10-15 years ago making them much easier to decipher.
                    Currently they send copy paper sized sheets which list everything with the car centered down the sheets with option codes and descriptions.
                    • Sandro C.
                      Infrequent User
                      • 6
                      understood. previous owner purchased them back in 1997.
                      • James G.
                        • August 22, 2018
                        • 808
                        Here is the link for Canadian Docs https://www.vintagevehicleservices.com/
                        It's been years since I ordered a set but IIRC 1997 is prior to the change in formats.
                        The old sheets show the information for multiple cars, so if you have the old style there could be another 10 cars(Corvettes, Impalas, etc) or more on the same sheet.
                        • Sandro C.
                          Infrequent User
                          • 6
                          Thank you for your help..
                          • Patrick B.
                            • August 31, 1985
                            • 2012
                            I have the old Canadian documents on my 67 Corvette. I think the new format will give you less information. The old format was a letter listing all the options on the car with the source material also included. The source material for mine was a sheet listing all the Corvettes imported into Canada in April 1967 with their vins, option codes and the codes for their keys. That was the documentation for my car and 25 others. I imagine they got a little worried about giving out the key codes for cars and quit providing the source document.
                            • Mark F.
                              • July 31, 1998
                              • 1597
                              Hi Patrick,
                              Who was the letter from ?
                              and do you now why GM of Canada did it that way vs probably no such thing in the U.S. ?
                              thx,
                              Mark
