Washer 1371261 finish and dimensions - NCRS Discussion Boards
  • Joseph A.
    • June 20, 2012
    • 136
    Does anyone know the dimensions and finish of washer 1371261
  • Leif A.
    • August 31, 1997
    • 3643
    Re: Washer 1371261 finish and dimensions
    Joseph,
    Washers - Flat .16 to .36 ID .33 ID X .75 D X .07 TK FLAT WA ZC. Electrolytic Zinc & Wax 1371261 B-11260
    Leif
    • Joseph A.
      • June 20, 2012
      • 136
      That is an AMK specification not a GM spec, this washer is also used for adjusting the alternator on Camaros, Novas, Chevelles, etc and I know they are thicker than .07
      • Leif A.
        • August 31, 1997
        • 3643
        If you say so...sorry for trying to help. If you don't know the dimensions, how can you be so sure those posted are incorrect?
        Leif
        • Gary B.
          • February 1, 1997
          • 7046
          Joseph,
          Over the years I have purchased many items from AMK, and in the vast majority of cases when they say something is zinc, they are correct. For the washer in question I suggest you contact Rich Pasqualone, whose contact info can be found in the archives. If he doesn’t have any of those washers, he’s still likely to know its finish and approximate thickness.
          Gary
          • Leif A.
            • August 31, 1997
            • 3643
            Does this make you any more comfortable? From Corvette Central...
            Includes:
            5/16 Split Lock washer- Zinc
            5/16 -18 x 1 Hex Head Bolt
            5/16 USS Standard Flat washer (3/32 Thick)
            Leif
            • Alan D.
              • January 1, 2005
              • 2046
              Understand Joe,
              However what is the year and use of said washer, those of us with older GM cats maybe able to find. (If too new my cats will not cover)
              • Joseph W.
                • February 20, 2022
                • 378
                I think you are looking for the alternator adjusting bolt and washer.
                The star washer is 9 tooth.
                The finish of the thick washer is zinc
                CBE4300D-F01E-42E5-9125-308BDD3B662F.jpgBE383A6A-F62B-4164-BDB9-34851D18CD69.jpg8DC5AA5A-5B09-43D9-B906-9A9F8A6346B8.jpg
                1971 coupe LS5 454/365hp
                1969 coupe L71 427/435hp
                1969 coupe L89 427/435hp
                • Alan D.
                  • January 1, 2005
                  • 2046
                  If you are looking for the alternator adjusting bolt, lock washer and flat washer have asked that question before, here are some comment from original cars and note that different years had different set ups
                  Small Bolt, 64AIM
                  Bolt 122017
                  SPL Washer 3792420
                  L Washer 187119
                  3792420 Spl Washer info
                  ID OD t
                  RJ .340 .875 .095 measured
                  MH .335 .875 .085 from his 66
                  HS .32 .51 .06 on his car,
                  Lindahl .375 .875 .125
                  Lindahl .31 .88 .09 AC kit for 64 has same washer
                  AKD .344 .8795 .0975 on car
                  65 Alt .349 .8780 .1115 AKD has
                  Sorry, worked on formatting for 30 min now and what shows up in preview is not what is written, think you can figure it out
                  • Gary B.
                    • February 1, 1997
                    • 7046
                    • Leif A.
                      • August 31, 1997
                      • 3643
                      Originally posted by Gary Beaupre (28818)
                      Alan,
                      Just for clarity for readers, “Spl washer” refers to special washer, not split lock washer. Correct?
                      Gary
                      That is correct Gary...in this case, anyways.
                      Leif
                      • Alan D.
                        • January 1, 2005
                        • 2046
                        Good point Gary, I just copied from the AIM (63-65) which is the same part, 3792420, for those years.
                        Note at one point the "split" lock washer, 187119, appears to have changed to an external tooth washer??
                        That's why we need to know the year car, please.
                        • Gary B.
                          • February 1, 1997
                          • 7046
                          Originally posted by Alan Drake (43261)
                          Good point Gary, I just copied from the AIM (63-65) which is the same part, 3792420, for those years...
                          • Alan D.
                            • January 1, 2005
                            • 2046
                            Gary,
                            Thank you, will update my file.
                            Did you check to see if the "split" lock washer, 187119, change to an external tooth washer during the C2 years?
                            I too only have a limited number of AIM's
                            • Gary B.
                              • February 1, 1997
                              • 7046
