2006 C6 Battery Disconnect Switch - NCRS Discussion Boards
+ More Options
Posts
  • Harry S.
    • July 31, 2002
    • 5344
    Has anyone successfully installed a Battery Disconnect Switch under the hood on a C6? It's going to be required at some events.
    I've tried two with the green knob, a blade switch and the black knob with the post pointing upward (see picture).
    There is no room for the blade switch or the normal green knob style. The black knob style will fit, but the negative cable will not tighten on the switch post, ug!
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11364
    Re: 2006 C6 Battery Disconnect Switch
    Harry do you have a dial caliper? Maybe get a measurement of your battery negative terminal and those various switches' terminals.
    You'll need 2 readings for each post, top edge and bottom edge.
    Rich
