2010 Tire pressure sensor problem - NCRS Discussion Boards
  • John T.
    NCRS Financial Officer
    • January 1, 1983
    • 292
    This morning all 4 tires register as 0. Actual pressure is 30 psi in all. Any suggestions as to causes or solutions will be helpful.
  • Leif A.
    • August 31, 1997
    • 3645
    Re: 2010 Tire pressure sensor problem
    John,
    Any work done on the tires recently? Could be the batteries in the TPM, they have a typical life span of 5-7 years. Seems unlikely that all four would go dead at the same time. I would drive it for a while and see if it doesn't rectify itself.
    Leif
    • Ray K.
      • April 30, 2005
      • 405
      John,
      Did you try re-setting your TPMS? On all four tires?
      If I remember correctly, the instructions are in the owners manual.
      However, I can't remember if the 2010s require a TPMS reprogramming tool . . . .
      If it does (and you don't have one) you can take it to your dealer and they should be able to do it for you.
      Ray K (#43777)
      • Michael H.
        • December 1, 1987
        • 730
        Try disconnecting your battery for 10 minutes and see if that resets the TPMS.
        Mike
        • Michael J.
          • January 27, 2009
          • 7145
          Interesting thing happened today to my 2021. After a software update download and installation, the TPMS went blank. There is a setting in the "Tire Pressure" menu to "Relearn", I am trying that now. These modern cars with all the electronic gadgets can be a real PITA.
          • John T.
            • January 1, 1983
            • 292
            After driving the car several times, the TPMS function has now started working.
            No clue as to why.
            John
            • Ray K.
              • April 30, 2005
              • 405
